Super Moderator
Getting starter out?
Any tips for getting the starter out?
I've removed the wiring and the two barrel nuts. Rorated the engine slightly back and forth, but it won't pull out and I don't want to pry it.. Is there something else? Oh, and now that I;ve forgotten to pay attention to which lead the larger trigger wire goes to, which one please?
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 03-20-2003 at 09:38 AM.. |
this is a bad cartoon.. so you tried to angle the starter out and maybe a slight pry w/a screwdriver???
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Super Moderator
LOL. Got the starter out...
Got the selenoid off. What do I lube, just the shaft? How to I get the selenoid spring thingy back on the lever ni the starter body? Th th th th that's all folks!
Rubber mallet or plastic deadblow hammer ... right-angle blows at side of forward starter body. Not on the solenoid.
As for the 'trigger' lead ... do you mean the #50 -- Yellow lead from the starter switch??? Only one of the small terminals will work, as the other one is connected to the special second set of contacts for the CIS startup enrichment solenoid ... not connected until solenoid is energized! It won't hurt trying the incorrect terminal ... your starter just won't engage, so move to the other one if the first try doesn't work!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-20-2003 at 10:31 AM.. |
Super Moderator
Warren, gotcha...
So do I just spread hi-temp lube on the selenoid shaft? (and Ron, much more like a bad dream right now... 5 months of careful engine rebuilding to end up here...)
Chris,
I always clean the solenoid plunger/shaft with CRC Brakleen, and then clean/polish/burnish with Scotchbrite. Likewise with the rocker/connecting link, and then apply moly grease liberally to the entire length of the solenoid plunger and pivot and ends of the link.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
and the crazy solenoid routine is when the solenoid movable core probably expands under heat, only an opnion on this.. anyway the old grease gets beat and hinders the big slide.. keep your sense of humor on this one.. stay away from sledge hammers and chain saws for awhile............ Ron
Super Moderator
Seems to move fairly easily now. I can rotate the starter with two fingers,.
Cleaned the ground strap contacts for the battery, the starter contacts, etc... The signal wires both connect to the same point... Is this the right starter for an SC?
Somewhere in the Midwest
Busy Bee, sorry I can be there. Good luck.
Souk, just think by the time Sunday rolls around Chris will be done and he can take us for rides.
Chris, sorry I cannot help until Sunday, but I have to ok to be away until 3:00 so I am willing to help then.
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
