Holy Burning Rat Piss
So it's finally a nice sunny day here in the Northwest. I fire up my SC and pull it out of the garage and on the floor under where the motor was is a small pile of chewed up sponge like rubber and a chunk of it. I inspect the top and the bottom of the motor as best I can and find nothing. H'mmmm, I take it for a drive and soon I smell burning rodent piss. i pulled the heat lever and really got a blast of the foul odor. After 30-40 minutes of driving it wasn't as bad. Any guess as to what the rubber piece is? So where do I look? Can rodents get into the SSI's?
Any help here? Dave
Hard to tell, but it could be part of one of the spongy foam blocks that fills the gap between the shock towers and the firewall. One on each side.
Foam behind rear shock tower replacement source? Mark
1979 911SC Targa |
Yes they can get into the heat exchangers - AMHIK. A number of years ago I started mine up after winter hibernation, began to smell some bad diner food. I must have had a whole family in my right HE. Could never fully get rid of the smell.
My routine now is to pull the heater levers up all the way in order to close the right and left heater control boxes. Then I stuff a dog toy into the exhaust pipe. Lastly I spread Irish Spring soap around, under the car (old wives tale perhaps). Jason
'79 911SC Targa |
PRO Motorsports
It’d be a really really good idea to remove the tin and ducting on either side of the engine fan and have a look for mouse nests on top of the cylinders.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Thanks guys and Tyson I will remove some tin and take a look. Damn rodents!!!
911timesThree
Get a cat...
GC (Garage Cat) will catch anything that moves in the garage and present it to me
1987 911ST 3.4L G50 LS 20/21 Granite Green Hot Rod 1988 911 3.4L G50 LS 20/21 Guards Red Hot Rod 2020 F87 M2 Comp 6Speed Carbahn 562/567 Gone: 1991 965 Black/Black Turbo Gone: 2002 E46 M3 6Spd CSL style build |
Yeah if all you guys were real men you'd run headers with no heat exchangers - then you wouldn't have any problems.
guy calls to go over the parts needed, then asks me how many dogs I have. ![]() I do not have any dogs, but I recalled the PO did. well mice has taken dry dog food up into the fan shroud area and stored them over in the crevasse near the heads. guy also noticed the valve guides were worse on the intake side which is not the norm. he suspects the stored dog food was causing spot overheating of the intake side of the head.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
I got the right side opened up and the little bastards have been busy. All vacuumed out and will move on to the left side.
Banned but not out, yet..
The little rat B@$t@rds like the dark to build their nests. In the winter months I keep the frunk, glove box door and engine lid open (as well as the heater levers up). Thanks to another poster, I will also plug the tail pipe.
An air cooled refrigerator. ‘Mein Teil’ |
Holy...!
Y'all, get yourself one of thos endoscopes (with LED-light-tip) für your Smartphone. Great helper!!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
My other ride is a C-130J
Besides the obvious of trying to ensure a sealed garage, I put rat poison blocks under my cars. If they are eaten or disturbed I’ll know I’ve got a problem.
I change them out once a year, fortunately they haven’t moved.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Schleprock
And welcome to the rodent nest club. We're a fine and distinguished club and we don't screen members. All that's required for membership is victimization. Here's my initiation into the club. I also found some on top of the engine, under the shroud. But the engine was peanuts compared to what I found in the tunnel (peanut pun TOTALLY intended) Winter Storage Tip
Kevin L '86 Carrera "Larry" |
Spiderman
You'll have to mention where you think they got all that stuff in there ?? Is it material from inside your car? I can't think of where else that much fluff would reside in the engine compartment unless its part of your sound pad. I've had lots of run-ins with mice years ago when my cars had to live outside here in the mountains. Has to be a pathway inside the car or something nearby in your garage being taken apart.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
I think you should remove the alternator so you can really get
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
PRO Motorsports
Man, did I call that, or what? lol!
Yeah, you should pull the alternator too, and after all the big stuff is out, use a shop vac, and then blow up from underneath with compressed air if you can. That stuff gets into every crack and crevice, so be thorough.
I am getting back to this project finally. So I am trying to remove the plastic duct from the shroud and it is not cooperating. Do I need to remove the distributor? Don't want to break anything. Thanks...
Damn rodents!
Hard to tell from your picture, but that shroud also has a tab that gets bolted down near the distributor by the cam boxes; looks like you might still have a bolt in there.
Rutager West 1977 911S Targa Chocolate Brown |
more mouse work...
Hads a fuel pickup / delivery problem at the Lime Rock Club race about a month ago.... after getting home opened up the fuel cell and found a mouse nest INSIDE the cell... un friggin believable....
I actually love to drive my car on the road, with my wife with me, and go on road trips to see the country. I plan to go to all lower 48 states. I am at 42 states now and I have been to Canada in my 911. Enjoy you no heat car, and do to it whatever makes you happy. I will enjoy my very comfortable heated and air conditioned car. ![]() I shot this picture of my car last November on a fall foliage tour. It was 16 degrees that morning. Withing one mile we had a nice warm car.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
