Runnin on empty
acme911's Avatar
Zinc Plating Questions
I will be sending out some parts to be Zinc Plated while my car is in for paint.
My question:
1) Door strikers. Can it be plated with the plastic or do I have to take apart?
2) Door latch mechanisms. Do they have to be dismantled? Or can they be left assembled? I really don't care about the main part inside the door. Just the exposed latch and screws.
Thanks, Andy
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 05-21-2019, 02:09 PM
For the strike, drive out the two small pins and the two plates rotate on the larger pin releasing the plastic bits. Careful with the plastic bits as they are NLA.
I didnt re-plate my latch, so cant help on that.
I was surprised to find out from my plater that parts with attached rubber bits can be plated complete, ex engine mounts.
HTH
1978 SC Targa
Old 05-21-2019, 03:55 PM
I have had plenty of small parts plated that have been attached to plastic or nylon.Never had a problem at all and the integrity of the non metal parts has never been compromised. I was a bit worried at first but the plater said that it is quite common and he was correct.
Old 05-22-2019, 03:32 AM
HTH
If you are talking about these...Rennline has replacement ones
Door Striker Repair Kit-Rennline, Inc.
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle
Instagram: @pdklol
Old 05-22-2019, 05:53 AM
Runnin on empty
acme911's Avatar
Thanks for this link!!
Old 05-22-2019, 12:51 PM
Under the radar
Trackrash's Avatar
Yea, I made the mistake of not removing the plastic from the striker plates when I had my stuff replated. I ended up having to replace them due to the plastic being mostly eaten away.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-22-2019, 01:14 PM
Unfortunately, those don't fit the original Porsche door strikes. They do fit the Stoddard Repros though.
Sierra Madre might have the correct ones -
Door lock striker
1978 SC Targa
Old 05-22-2019, 01:21 PM
