Sources to rebuild 964 distributor?
Belt broke a couple weeks ago while doing a few dyno pulls. Put a new belt in the dizzy but not comfortable with 28 year old bearings in there. Don't have the time to tear it all apart, so looking for recommendation to do a proper rebuild for me.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Any recommendations?
Northern Motorhead
Ed,
There's a local Rennsport PCA member who rebuilds those , he charges $700. Canadian ... i have no affiliation with the guy buy you can reach out to him at -> fm395@ncf.ca His name is A.Clanner , if you can't get hold of him and this works for you , let me know and i'll try on my end. I have no idea whatsoever how much those rebuilds go for, so this is only a suggestion !
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Perpetual Reassembler
I had my SC distributor rebuilt by Kurt at Parts Klassik
Did a great job. Might want to reach out to see if he does 964 ones as well.
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
I was looking into this recently. For similar price I could get an older style 12 point dizzy, get rid of the belt issues, and have a cool look for the same price. Just a thought.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Kurt at Parts Klassik.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
Thanks everyone. If the going rate for a rebuild in as much as $700 I'll source the bearings and do it myself. I already had the distributor apart to replace the belt and it's simple work. Bearings can't be more than $100 so I'll save myself $600 in labor for the couple hours of work. Was just trying to save myself the time.
Northern Motorhead
Ed,
That was in Canadian money !!! Here is the quote in Rennsport from the guy who rebuilds them ... if you do it yourself, i guess the real issue is finding the correct parts. They are rebuilt properly using all four "new" bearings, a new belt and drive pin. Replacing just the belt is not the solution since a seized bearing is the cause of failure. Bosch specific (non-standard) FAG and INA bearings are sourced from Europe which I pick up while on vacation there.
