Harpo's Avatar
Header installation
Good evening everyone,
For those of you with headers what did you use to reroute your oil lines?
Old 05-08-2019, 03:06 PM
Harpo's Avatar
I don't currently have a trombone or any cooler. Living in Michigan does have some advantages
Old 05-08-2019, 03:09 PM
911SC Tinkerer
merlinfe's Avatar
Depending on the headers you will have to get backdated oil lines. Look in the Porsche PET for part numbers and search around. They are available on Pelican and will need to be massaged to fit. There are other flexible alternatives but I don’t have experience with those.
Good luck and get a Mapp torch, your going to need it.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 05-08-2019, 03:14 PM
Harpo's Avatar
Mapp torch? All of my exhaust studs are out. I used a hand held induction heater that I borrowed from work. Am I going to need to borrow it again to remove the old oil lines?
Old 05-08-2019, 03:21 PM
Harpo's Avatar
Is # 33 what I need? 911 107 739 10
https://www.pelicanparts.com/More_Info/91110773910.htm?pn=911-107-739-10-M127
Old 05-08-2019, 03:28 PM
When I installed my Rarlyl8 headers, I didn't have to reroute any oil lines.
Make sure that the headers you plan to install do not interfere with access to the lower valve covers.
Old 05-08-2019, 03:31 PM
911SC Tinkerer
merlinfe's Avatar
Like everything in life, it depends. I had to use a Mapp torch on the union you see in the far right of your picture ( by the hanging heater ducting). This was after soaking the union in Kroil. What really worked for that thing was a pipe wrench with a long breaker pipe and a 4x4 post supporting it from the ground. It was the only way I could remove it with out damaging it too bad. Good luck.
-Steve
-'83 911SC Coupe
Old 05-08-2019, 03:33 PM
Oil line for header installation........
Originally Posted by Harpo View Post
David,
You need part #33. I had a minor problem with the new oil lines from our host during installation. The new ones is not shaped or formed exactly like the old ones. So you should be aware of this problem. Unless the new batch has been modified, it would not mount correctly on the motor without massaging it.
Tony
Old 05-08-2019, 07:43 PM
Cory M's Avatar
I used the factory Porsche early oil lines, no problems with fit or need for torches, maybe I got lucky..
Old 05-08-2019, 08:23 PM
Oh hell, the old style oil line was such a bear to get in place for me. When connected at the engine sump it was originally a good 2" off from the connection at the heads, and not only that I had to bend it even further out to clear the header and then back in.
I was very mad at that thing. Very mad.
Good luck!
Old 05-09-2019, 07:26 AM
Harpo's Avatar
Do I also have to replace #20 also?
Old 05-09-2019, 07:50 AM
Harpo's Avatar
Does anyone have a used one in good condition
Old 05-09-2019, 08:06 AM
I might have one. I'll check the garage.
Lost 2.7l engine #6141641, drop me a line if you find it.
Old 05-09-2019, 08:14 AM
New-ish 911SC Targa Owner
pampadori's Avatar
I had to replace 30 and 34 with my BBE headers. I ended up making something work for #34.
Had I bought them new, it would have came with a pipe to replace it with but i'm cheap and went used!
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 05-09-2019, 09:29 AM
porsher
aston@ultrasw.c's Avatar
Another strategy is to go up and over. Len makes a variety of excellent parts. He lurks on the forum and may comment in the near future
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 05-09-2019, 11:36 AM
porsher
Len Cummings aka BoxsterGT
79 928 Race Car
Old 05-09-2019, 11:40 AM
Harpo's Avatar
I just ordered # 20 & 33 from our host. I ordered a 36mm box end wrench from Amazon
Old 05-10-2019, 09:22 AM
Harpo's Avatar
My mechanic just made me a 36mm wrench. He cut a socket on the lathe then welded it to a handle that he water jet cut for me
Old 05-10-2019, 10:03 AM
pampadori's Avatar
Wilding Engineering sent me one of their 36mm wrenches with my engine lift adaptor. Not sure if our host sells them or not, but you can also get them directly from Wilding here. The opening makes it very handy for the oil lines.
Old 05-10-2019, 10:38 AM
How do you get that wrench around an oil line fitting with it installed? And the reverse after you have tightened the fitting? Do you plan on cutting a relief in order to facilitate these things mentioned?
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 05-10-2019, 12:24 PM
