Originally Posted by HarryD View Post
True but they are not available here at a reasonable price.
Actually cheaper than Brad Penn and many others... Please check!
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 05-27-2019, 05:41 PM
Originally Posted by tdw28210 View Post
I suspect that oil is for older engines. I am very happy with
Liqui Moly Touring High Tech 20W50. See Data Sheet.
with MoS2 added on top.
Old 05-27-2019, 05:49 PM
HarryD's Avatar
Maybe for you. I can get Liqui-Moly here but it costs more than the Brad Penn I can get. Others are more expensive.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-27-2019, 06:05 PM
HarryD's Avatar
Also, FWIW, when I had my top end redone, my mechanic originally put in Total 20W-50 Syn in the car.
I had a lower oil pressure and a VERY high oil consumption. I discussed with him and we agreed to try BP. Pressures were normal (about 10 psi/1000 rpm) and my oil consumption drastically improved.
Harry
2020 MB E350 4Matic
Old 05-27-2019, 06:11 PM
Thank you everyone! Going BP20W-50!
Old 05-28-2019, 08:50 AM
toddadale's Avatar
I've been drinking the Brad Penn koolaid myself for 12 years.
Much better way to go with these older engines? Liqui Moly 20W-50
My 3.2 at 107k miles never felt so smooth with "Liqui Moly 20W-50 Touring High Tech Motor Oil: - Tossed in 2 cans of Liqui Moly Anti-Friction Engine Treatment (shake the cans before putting in the oil)
Just, smooth as silk.... Make the change; you will not regret it.
Only issue is you have a hard time buying them in quarts!
If everything seems under control, you're just not going fast enough.
Mario Andretti
Old 09-21-2023, 09:56 PM
HarryD's Avatar
Originally Posted by toddadale View Post
I've been drinking the Brad Penn koolaid myself for 12 years years myself. My 3.2 at 107 miles never felt so smooth with Liqui Moly 20W-50 Touring High Tech Motor Oil - tossed in 2 cans of Liqui Moly Anti-Friction Engine Treatment. Smooth as silk. Make the change; you will love it.
My FLAPS carries LiquiMoly and I switched to it a few years back. Seems to work well with no drama.
Harry
2020 MB E350 4Matic
Old 09-21-2023, 10:02 PM
AndrewCologne's Avatar
Liqui Moly states that their "Touring High Tech 20w50" and their "Formula Super 15w40" both come with a ZDDP content of about 1200 ppm.
https://forum-liqui-moly.de/index.php/forum/motoroele/209-motoroel-fuer-oldtimer-v8
https://forum-liqui-moly.de/index.php/forum/motoroele/1580-zddp-anteil-lm-1440-formula-super-15w-40
Also explained here:
https://nineelevenheaven.wordpress.com/oil-varieties-for-the-911-sc/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 09-21-2023, 10:57 PM
