El_Mecanico's Avatar
Porsche engine yoke strong enough?
I just received the motor yoke to attach to my engine stand and noticed there are two mounting points only. I'm use to clamping on the standard 4 point. Is this strong and safe enough to hold my 3.2 engine completely assembled? And if so do I need to install bolts or just slide spacers over the existing studs?
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 12-11-2011, 07:00 AM
Hi
Targa Me's Avatar
Hopefully someone will chime in on this.
Two point just doesn't seem right to me.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 12-11-2011, 07:03 AM
ROW '78 911 Targa
timmy2's Avatar
2 points with the flange mounted flush to the case to spread the load is enough.
Do a search on Yoke and you will see many pictures of them doing exactly what you are asking about.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-11-2011, 07:30 AM
al lkosmal's Avatar
3.6 on the stand
I've had quite a few engines on this stand. Here is the heaviest....a monster 3.6.
The yoke works just fine and is designed to mate with one case half, allowing you to tear down your engine and split the case, while mounted to the stand.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 12-11-2011, 07:39 AM
arbita1's Avatar
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-11-2011, 08:03 AM
Thank you for the rapid feedback.
Almost Banned Once
sc_rufctr's Avatar
Call me stupid if you like but I wouldn't do that.
I understand it may be common practice but I would not load up the yoke like that. You're asking for trouble IMO.
A naked engine would be fine but that just looks like an accident waiting to happen.
Once the engine is together (basic main engine, exhaust only) you should mate it up to the trans on a lifting table or similar and then put on the ancillaries/fuel injection etc.
regards,
al
- Peter
Old 12-11-2011, 08:15 AM
I have after market version and the piece that attaches up against the engine is about 1/4 inch thick. I'm not to comfortable with it.
Old 12-11-2011, 08:54 AM
ROW '78 911 Targa
timmy2's Avatar
E-Bay Yoke in my garage a month or 2 ago!
No problem. Mounted on left side to allow oil cooler to be mounted.
Dennis
Old 12-11-2011, 09:02 AM
ROW '78 911 Targa
timmy2's Avatar
One more (crappy picture)
Dennis
Old 12-11-2011, 09:06 AM
arbita1's Avatar
Same one in my photo above.
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-11-2011, 09:07 AM
Porschedr.'s Avatar
No Porsche has no idea what their doing.
Jesus.
Old 12-11-2011, 09:08 AM
ROW '78 911 Targa
timmy2's Avatar
Your's looks dirty.....
Dennis
Old 12-11-2011, 09:13 AM
al lkosmal's Avatar
There seems to be some precedent set here....by the factory. Granted , that looks like a "T" MFI motor down at the end of the line, so it's a bit lighter than the 3.6. I've rebuilt a few engines on my stand, from 2.2, 2.7 thru 3.6...absolutely no problems, whatsoever with the right yoke that distributes the load properly.
You never know...the Porsche tool designers may have thought about this a bit.
regards,
al
RGruppe #669
Old 12-11-2011, 12:38 PM
Diss Member
Quicksilver's Avatar
By the same token: Only 4 studs to hold on the transmission and transfer all the torque of an engine that can be turbocharged past 700 horsepower! GAAACKKK!!!
But obviously it works because no one has failure issues on this part of the design.
The yoke is way past plenty strong. The important part of the strength is having a strong, stiff mating surface to spread the load. If the mating surface can flex then you can have an issue.
The studs do not support ANYTHING with any side loading. They are simply supplying a clamping load so that the width of the yoke can do ALL of the supporting.
This is much ado about nothing. This is a lack of understanding about the structural issues involved. The factory didn't screw this up as more then 45 years with zero issues has shown.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-12-2011, 09:22 AM
kodioneill's Avatar
I agree with the other posts. Porsche knew what they were doing. That yoke is plenty strong. ( Porsche tool P201) not the Ebay crap.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-12-2011, 11:38 AM
There is nothing to worry about.
Old 12-12-2011, 12:13 PM
I have the ebay crap...will it work?
Old 12-13-2011, 03:29 AM
arbita1's Avatar
Yes. Just make sure its the 5 arm one.
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-13-2011, 04:22 AM
Banned
I've had a competely assembled turbo engine on one (including the complete turbo/exhaust/fuel system/intercooler etc) - no problems.
Old 12-13-2011, 06:10 AM
