clutch throw out fork issues
'83 911 sc. Just installed a rebuilt clutch with new fork and bushings. adjusted everything. Cable pull measurements all good. Started engine. Depressed clutch pedal 3/4 way scrapping noise. Pulled engine out, as per pictures pressure plate rubbing new fork. Any idea? Did I install something wrong. Was so careful making sure fork was engaged it throw-out bearing.
Thanks for any info.
Mike
Old 06-06-2019, 03:04 PM
proporsche's Avatar
are you sure the clutch disc is in the correct way? also the TO bearing and shims has to be correct..
on the outside with the To bearing goes 1st the spacer shim then the sunshine shim ,facing away from bearing.Then you put the bearing into the press plate and put on the ring and after the clip...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-06-2019, 03:12 PM
I had a local shop, South Bend Clutch, rebuild and resurface the flywheel.
They have been around for decades, and very reliable.
I may take it off and take it back over there if plp think that could be the issue.
Old 06-06-2019, 03:19 PM
I might guess that the disc is too thick. Notice what looks like excessive convex angle of the pressure plate diaphram spring. In other words, it sticks out too far, along with the t/O bearing. When the disc wears out and gets thinner, it flattens out more. Just a guess. 8.1mm is the relaxed thickness of a stock one when new.
206 637 4071
Old 06-06-2019, 04:55 PM
Thanks, I will take assemble back to SBC tomorrow for review.
I also noticed the new fork is .035 thicker than the old one, I set it up on some vblocks. Don't know how close everything in the bell housing is.
Old 06-06-2019, 05:29 PM
Just removed and measured my disc .382, 9.7mm.
Old 06-06-2019, 05:50 PM
There ya go. That's why I buy new.
206 637 4071
Old 06-06-2019, 07:04 PM
proporsche's Avatar
yes to JW...i wonder about "Just installed a rebuilt clutch" how did you rebuild it..You did not use new clutch parts?
Ivan
Old 06-06-2019, 11:50 PM
