Ron...fair question. Maybe I should have said, pick one path and follow it. Tony is good at guiding/insisting on an orderly approach. When someone has yet to master CIS basics, they often seem to struggle and flip around all over the place. No disrespect intended to other CIS gurus out there....I keep learning from all of you. John
vacuum line missing?
Shouldn't there be a vacuum line attached here on the WUR of my 1980 SC? I'm getting ready to a vacuum leak test and I see in the Pelican How-to section they show a vacuum line on this.
Mighty Meatlocker Turbo
On the turbo WURs that is simply a pressure vent so that the diaphragm inside the WUR can move freely. If the diaphragm ever ruptures, fuel flows out of that, and in stock trim, a hose is connected to it, and then to the air filter housing, so that fuel doesn't spill onto the engine. |
What hose should I attach the smoker to test for a vacuum leak?
CIS troubleshooting..........
Mark, First, your WUR-072 is not vacuum assisted. Vacuum is never applied and used for this particular type of WUR. Some of the advises offered to you makes sense others are just garbage. So be careful whose direction to follow. I have a strange feeling that you don’t know or understand how to use the Smoke tester tool you have. You need to isolate the CIS unit (airbox, throttle body, and intake runners) to perform a pressure test using a smoke generator or machine. You need about 5 mins. to do your fuel pressure test and 30 sec. for your vacuum or air leak test. Do these two (2) tests first to understand what is going on with your engine. I am betting my money on unmetered air. So what happened to the missing rubber hose connected to the top of your WUR? You might have also a nipple at the throttle body left unplugged. Could you post a picture of the throttle body and air filter housing? Thanks. Tony |
Tony,
Are you referring to the nipple I circled in yellow? I don’t recall seeing a hose there and it doesn’t look like one was ever there. Pelicans tech article on Vacuum Leak Test shows the picture below. A hose going to the WUR. Are you saying I am missing that?
Telephone camera........
Mark, For this investigation, just remove the air filter cover (snorkel) like shown in the above picture. I like to see the area between the throttle body and air box from the driver side viewpoint. There are two (2) small nipples above the butterfly valve on the throttle body. Thanks. Tony Last edited by boyt911sc; 06-16-2019 at 10:46 AM.. |
Throttle body ID number.........
Mark,
In the second picture where the black/blue hose is connected, there should be another smaller nipple. Now, to get to the bottom of your problem let’s identify your throttle body. Look closely in the last picture you posted. To the lower left of the spring is an aluminum strip I refer as label. Please post the last 3 digits stamped on the label and post the number. While you are there, take also a look at your fuel distributor number. Post the last 3 digits. Thanks. Tony |
Thanks for your help but I’m going to take it in to a shop. I’ve driven the car a total of 140 miles since I bought it last year. Going back to my 1965 Mustang. Closed thread. I’m out of here. |
Good luck.........
Mark, ![]() Encircled is the aluminum tag or label for the throttle body. I think you are making a good decision to take it to a shop. Tony Last edited by boyt911sc; 06-16-2019 at 02:39 PM.. |
Mark,
When you take it to a shop have them set the idle mixture. I have attached a link to CIS Flowtech web site that details the process. Bosch K-Jet Mixture Setting - CIS Flowtech
Dave K |
Still here
Sorry to see Mark go before any technical resolution to his CIS issues.
Just want to add that ... ... suggesting someone tune everyone else out is not going to help anyone do that. The more current and future experts there are in any topic and the more inviting and welcoming we are to their input, the better it is and will be for the forum. |
While I doubt anyone can totally replace Grady Clay, this post really sums up what this BBS is about and how Grady viewed our obligation to the fellow users:
