Idle up, idle down, dies
I know this has been covered before, but still looking for advice as I think my problem is unique.
I have a 1980SC and it idles up and down rapidly warm or cold. If I don’t give it gas it dies. I took it to a shop (well known) when it only did it when it was cold. Now it does it all the time, cold or warm. Shop doesn’t know why and said they are not at fault for it being worse. I have some mechanical abilities and want to fix it myself. If I need to buy some special equipment I’m ok with that. Thanks for any advice. |
CIS troubleshooting..........
Mark, You need a set of pressure gauge to check your fuel pressures (CCP, WCP, & SP). A homemade smoke tester will help you find those hard to find air leaks. A shop with gas analyzer could read measure or check your fuel mixture. Is your WUR -072? Keep us posted. Tony |
What is a WUR? Is -72 the reading and how is it measured? |
Still here
A good start is to snip 10mm off the ends of the rubber vacume hoses and refit them. They get a bit loose and the vacume is lost.
With another SC with similar symptoms I opened up the AAV and cleaned it, although it looked already clean, and put it back together. This stopped it's rev fluctuating thing it was doing. A couple of easy first trys, and good luck. |
Acronyms.........
Mark, Sorry for assuming you are familiar with the common acronyms used in this forum. Don’t worry, we all started like you from the beginning. These are the most common acronyms you will encounter with CIS (constant injection system) discussions in this forum. AAR (auxiliary air valve) AAV (auxiliary air valve) AFS (air flow sensor/switch) CSV (cold start valve) DV (deceleration valve) FD (fuel distributor) FP (fuel pump) FV (frequency valve) CCP (cold control pressure) RP (residual pressure) SP (system pressure) TTS thermotime switch) TV (thermovalve) WCP (warm control pressure) WUR (warm up regulator). Etc. Find some reference manuals or books to read about Ketronic system and understand how the system works. Your WUR should be 0 438 140 072 for USA spec ‘80. -072 is the last 3 digits on your WUR. Tony Last edited by boyt911sc; 06-08-2019 at 05:10 PM.. |
bennysc1
I have an 83 SC with same problem. It appears to be the auxiliary air regulator having the issue.
Will get on it and thanks for all the info. Didn’t realize these were so complicated. Spent most of my time with older American cars.
Still here
Mighty Meatlocker Turbo
Mark, here is an old school instructional video about the K-Jetronic/CIS system; it is very helpful with regard to getting to know the various components and what their functions are (and pmax above, better known as pNutz, just luvs the from-VHS transfer skipping
What fuel pressure gauge set do you recommend? I see lots of different ones recommended. Mark |
I have a Hofman-kit, but that's not for sale anymore.
For the best wipersblades in The Netherlands and Belgium: www.nieuweruitenwissers.nl |
Start with the easy, no equipment need either - see post 5
Basic pressure gauge tool........
Mark, I recommend the S&G CIS pressure gauge tool kit. I don’t remember the exact model # because I bought them a long time ago. I have 3 sets by the way. Do not buy the expensive one just pick the basic kit with 12-mm x 1.5 fittings and has the range of 0~100 psi. They usually come with different brass adaptors but you only need one 12-mm x 1.5 male/female adaptor for your control fuel pressure tests. Tony |
The first thing I would check if the frequency valve is working. The FV relay is located under the passenger seat, If you pull the relay, its a cube, while its running and the idle doesn't change that is your problem. On 1980, 81, 82 qnd 83's. ALWAYS check if the FV is working first. Please keep us up dated.
Dave K |
Designer King
Your symptoms are usually those of a too rich condition. As others have mentioned, you will need to check your fuel and control pressures to help determine this. The WarmUpRegulator is often the culprit causing this. They go out of spec and the bimetal strip inside fails.
Again, per others, vacuum leaks are common and often people richen the mixture too much to make up for them. Once you post the fuel pressures we can compare them with the spec
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
What does that mean? |
Also buying the S&G 338000 CIS fuel injection tester. Has the correct fittings according to Tony. Will check my WUR because my car does run rich. Wouldn't pass smog here in California. I have a Bentley Porsche SC service manual but don't see info on the WUR. Where is it? Will post results. |
