-   -   3.0l CIS upgrades? (http://forums.pelicanparts.com/porsche-911-technical-forum/1032022-3-0l-cis-upgrades.html)
Kwalls 06-12-2019 02:07 PM
3.0l CIS upgrades?
3.0l CIS and need guidance/suggestions on upgrading HP
http://forums.pelicanparts.com/uploa...1560373389.jpg
Jack Stands 06-12-2019 02:15 PM
Have you seen Bruce Anderson’s book? I think that other than changing to 964 cams or increasing displacement, your options are limited with the CIS injection.
darrin 06-12-2019 02:21 PM
believe swapping to a 2 out (e.g. ssi) exhaust helps out too.
Kwalls, welcome to the forum -- looks like you've already hotrodded your SC -- what have you changed up on it so far?
Kwalls 06-12-2019 02:32 PM
I have not looked at his book but, will check it out! I'm thinking of 964 cams and going with PMO's just not sure if the cost levels with the gain in hp?
Kwalls 06-12-2019 02:48 PM
Love this forum! The car has had the following from the previous owner:
- engine rebuild & gearbox
- 16x7 & 9 fuchs
- open can sport muffler
- suspension upgrade
Super fun and I have a lot to learn
jac1976 06-12-2019 02:50 PM
Switch to 15s. Did I beat Bill to it?
Trippyloaf 06-12-2019 06:04 PM
What’s going on here? Looks like it might be setting you back. SmileWavy
http://forums.pelicanparts.com/uploa...1560387819.jpg
LakeCleElum 06-12-2019 07:08 PM
Kay Wall(s): In my 73.5 with short gears:
My 3.0 with CIS is reportedly making 209 HP at the rear wheels. Here is a copy of the ad from when I bought the used engine: Note is has high compression 3.2 and early exhaust also:
Recently removed upgraded '81 SC engine and transmission from my '81 SC after car was damaged in front, causing parting out the car. Upgrades include 1) Max Moritz 3.2 liter pistons and cylinders, 2) 964 cams, 3) Raceware hardware, balanced rods, Carrera oil pump. New parts included: intake valve sleeves, rod bearings and rods balanced, and rocker arms.
juanbenae 06-12-2019 07:34 PM
carbs are the best way to get more HP out of a CIS equipped car.... :D
especially is you are already considering cams.
Trackrash 06-12-2019 07:45 PM
Especially if you replace the pistons as well....
Rawknees'Turbo 06-12-2019 08:40 PM
http://www.puppetdesignstudio.com/wp...veman_club.jpg
pmax 06-12-2019 09:53 PM
http://forums.pelicanparts.com/uploa...1560401577.png
Jonny H 06-12-2019 11:23 PM
See post 206.
http://forums.pelicanparts.com/porsche-911-technical-forum/894670-classic-retrofit-cdi-dyno-results-11.html#post10483546
Bill Douglas 06-12-2019 11:45 PM
SSI exhaust system adds some HP and loses weight from behind the back wheels.
Flojo 06-13-2019 01:35 AM
SSI and Max&Moritz-tuning with 3.2 Pistons
Nux 06-13-2019 02:54 AM
+1
although a little expensive, this is a well proven and plug & play solution with no other mods needed. About 220-225hp.
RarlyL8 06-13-2019 06:44 AM
We supply modified CIS components for race cars. The fuel distributor is modified for higher flow and the WUR can be made adjustable if needed to compensate. This is generally done to satisfy spec class rules. If your class has no rules on induction then carbs will give a bigger bump. The difference in fuel mileage and smoothness is noticeable however and a consideration.
juanbenae 06-13-2019 08:41 AM
Originally Posted by pmax (Post 10489953)
OK pnutz, that one made me laugh out loud....
G450X 06-13-2019 03:09 PM
You didn’t mention what year your SC is, but from what I’ve read, early (‘78/‘79) U.S. or euro CIS is a bit simpler and flows better, and will better compliment the 964 cams, higher compression stock pistons & cylinders (or Max Moritz 98mm), SSI’s, exhaust, etc..
If you find additional coin, a 915 with shorter gears, or R&P swap can enhance the mechanical advantage as well.
Good luck, an SC on a bit of a diet with a slightly tweaked engine can be fun and reliable...
jac1976 06-13-2019 03:27 PM
Also the 3.1 kit and Webcam 20/21 grind
