Kevin Stewart's Avatar
Anyway to read codes on a 3.6 conversion
Hi I think I have something going on with the idle on my 3.6 conversion any way to read the codes. Thanks Kevin
Old 06-14-2019, 09:30 AM
Tom '74 911's Avatar
Kevin,
I have a '90 3.6L engine installed in my '74 911 and have used the check engine light to read codes via a procedure outlined in the 964 Workshop manual. I have most of the Patrick Motorsports conversion wiring harness which has a provision for the check engine light - see the single, loose green wire in the first photo below. It also has a provision for a code reader, but I do not have easy access to one and am not even sure if it would work for early 3.6L engines.
I wired the green wire to a light and followed the procedure outlined in the second attached image... you have to read the long vs. short blinks and then look up the code of the corresponding number - which I'm fairly certain is the 3rd to last column in the 3rd attachment...
I did this a while ago and don't exactly remember how it all goes to be honest, but it DID work for me. I got the "All is good" code...
Hope this is helpful & best of luck troubleshooting!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 06-14-2019, 08:40 PM
