-   -   Sluggish battery is measuring 13.25V while engine is running. (http://forums.pelicanparts.com/porsche-911-technical-forum/1032433-sluggish-battery-measuring-13-25v-while-engine-running.html)
sugarwood 06-17-2019 06:36 AM
My 911 has been doing a lot of sitting recently
Recently, I trickled charged my battery, yet it does not feel 100%.
Slight sluggish hesitation on the first few cranks, before firing up.
I drove it 30 minutes a few days ago, yet there is that sluggish crank.
Today, I drove it for 10 minutes, pulled into the driveway, and it would not restart.
Engine off, battery measures 12.5 volts (80% charged, see link below)
Engine running at idle, battery measures 13.25 volts
This is lower than the last time I measured.
When the battery was new, voltage would read 13.6v (engine running)
Alternator was replaced in 2001 (20k miles ago)
I bought the AGM battery about 2.5 years ago.
But, it has been trickle charged from totally dead perhaps a dozen times since.
I am going to trickle charge it overnight, and see if the voltage can get up to 12.7v (100%)
I will also measure voltage with the RPM's higher than idle.
I'll also check the ground strap and the connections at the starter and alternator (battery is clean)
https://www.emarineinc.com/Marine-Batteries-Maintenance-101
Thanks for all the advice.
I brought it to the store.
They verified the battery was bad.
Turns out, the AGM had a 4 year warranty.
So, I got a replacement for free.
New battery is obviously stronger
Cranks like a bumblebee on Adderall now
Car off 12.8v
Running 13.7v
Back on the road!
I will try to change that strap, either way.
Thanks again for all the advice.
darrin 06-17-2019 07:21 AM
sugar wood, why not take it to a FLAPS and have them do a free load test on the battery? That'll rule out a failing cell
pampadori 06-17-2019 08:44 AM
ground strap from transmission to chassis. Had same symptoms on mine years ago and that was the root cause. It was a braided metal strap and was quite dirty and oily. Even clean it had too much resistance and had to be replaced.
dhanl82 06-17-2019 09:31 AM
Battery
With a charged battery at 12.5 volts, you should be seeing the voltage that the alternator is charging the battery at. My 82 SC alternator was charging at 13.2 - I replaced ground strap and it went up to 13.7
sugarwood 06-17-2019 02:21 PM
I've got it on a charger, and will measure the voltages again tomorrow.
I actually have that tranny ground strap sitting on my shelf for years.
When I tried to replace it a few years ago, it was harder than it looked.
I could not even see the stud so I bailed out.
I will get under the car again this week and take another look.
Snitzler 06-17-2019 02:33 PM
Try this....
http://forums.pelicanparts.com/porsche-911-technical-forum/962014-how-r-r-transmission-chassis-ground.html
911pcars 06-17-2019 10:31 PM
System voltage supplied to the vehicle while running falls to the alternator. Should be around 14 volts.
If the charging rate is 13.25, raise the idle a little. 13.25 is a bit low Put a load on the system (headlights, motors, window defroster, other electrical accessories ON). See if the charging rate increases. It should. Otherwise, the battery will be operating on a deficit (discharging) and it may discharge to a threshold below cranking voltage.
Sherwood
sugarwood 06-18-2019 04:08 AM
After a night of charging
Car off 12.5v
Running 13.6v
Lights and heat running 13.2v
Bob Kontak 06-18-2019 04:52 AM
Originally Posted by sugarwood (Post 10495452)
Car off 12.5v
Running 13.6v
If those numbers were three tenths of a volt higher across the set I would say fine. The 12.5v raises an eyebrow.
I would start with a battery check at parts store as suggested.
RedCoupe 06-18-2019 06:34 AM
+1 The ground straps and the main battery ground cable should be checked for resistance, not just cleaned. They get internal corrosion, so need to be replaced from time to time.
T77911S 06-18-2019 07:00 AM
CLEAN battery connections AND the ground strap first. you don't have to replace anything.
a fully charged battery is 12.6 volts. some could be around 13v. depending on if it is 2.1v per cell or 2.2v per cell or look up the data sheet for that particular battery to see what the charging voltage SHOULD be and what the voltage is fully charged.
your issue is not really anything you have measured.
measure the cranking voltage. if it is less than 10v the battery is bad.
OR, take it to some place like advance and let the load test the battery to remove all doubt.
if the battery is bad clean every thing and check you voltages again with a good battery.
if you suspect a charging issue, again, take it to an advance and let THEM test it for free. don't guess at what or if anything is wrong.
Bob Kontak 06-18-2019 07:22 AM
+1
The machine they have locally can tell if there are oddball things with the alternator as well. Not just charging capability.
With respect to ground, I have used jumper cables from engine to ground on BMW's with corroded ground straps just for a test. I could then get the car to start. The braided cables were essentially green dust though.
darrin 06-18-2019 07:49 AM
+2 -- getting battery capacity/health tested makes sense as a first(ish) step whenever it's been completely discharged in the past AND one is having charging issues. It's low-hanging fruit -- rule out the battery before tackling other (more difficult to address/rectify) possibilities.
911pcars 06-18-2019 11:41 AM
Your FLAPS may have the latest state-of-the-art battery tester. It tests battery conductance, a very accurate method that can test 12v lead acid batteries in various states of charge. Testing doesn’t require charging or potentially hazardous load testing and is more accurate. More details here:
CONDUCTANCE TESTING QUESTIONS AND ANSWERS
I should have added; the parts store may use this type tester to test customer batteries. Typically no charge and lots more accurate than inexpensive testers.
Sherwood
ClickClickBoom 06-18-2019 11:47 AM
Battery is failing/dead. You cannot let a lead acid battery go dead, everytime you do it dies a little bit more. The reason the alternator running voltage is so low it is trying its best to charge a dead battery, and is instead is producing heat. Buy a flooded lead acid battery and keep a CTEK smart charger on it whenever not in use.
sugarwood 06-18-2019 12:53 PM
Thanks guys.
I suspect it's been dead too many times over the last year.
I will buy this for $20 and load test it myself.
https://www.harborfreight.com/100-amp-612v-battery-load-tester-61747.html
<iframe width="560" height="315" src="https://www.youtube.com/embed/qP5r6NB0ypo" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Bob Kontak 06-18-2019 02:23 PM
Originally Posted by sugarwood (Post 10496016)
Thanks guys.
Yep. This is a nice tool to have on the shelf for the battery test. You will use it plenty across time.
A toaster with cables. Not sophisticated but functional.
sugarwood 06-18-2019 03:05 PM
What is a load test?
It measures how much voltage is supplied during load?
A damaged battery can measure 12.5v, but will measure less under load?
darrin 06-18-2019 03:24 PM
sugar wood -- yep -- all covered in the video posted above -- meter shows voltage with no load and then shows voltage drop when load is applied (toaster with cables comment by bob k is spot on)
I do like the info that Sherwood (911pcars) provided above about how the FLAPS (friendly local auto part store) uses a more sophisticated conductive tester to determine battery health/condition -- plus, having the FLAPS run the test for you has the added advantage of saving you the cost of a load toaster :)
Bob Kontak 06-18-2019 03:26 PM
Yes to second sentence.
The load test tool routes the battery juice through heavy coils (toaster coils) that put a "load" on it similar to starting.
As one member noted, check voltage while cranking. The toaster tool does the same thing. When you flip the toggle switch at the bottom of the tool it subjects the battery to a big draw of power.
If your battery is robust, the needle will drop some when load tested but pretty much hang near 12v, maybe a touch less but not much. It will continue providing power across time (many seconds). Especially, if fully charged.
If the battery is crippled, the needle will sink to the left. Sometimes slow, sometimes fast. If it sinks slow, repeated load tests will erode voltage if the battery is compromised.
sugarwood 06-18-2019 05:56 PM
Thanks, great info.
I'll do this in the next few days.
sugarwood 06-18-2019 05:57 PM
When my ground strap failed me, i too was getting 13.2-13.6 volts when i checked it. But then i'd go for a drive and come back and that number would be more like 12.8-13.0 while running. It would charge for a little while but then go downhill as things warmed up.
It really is super simple to test. Take your jumper cables and use them as a temporary ground cable from your fan shroud to the chassis somewhere. I used the metal plate that the CDI was bolted to i believe. Adding this new path for current to return will immediately improve your voltage so you can verify it in literally 3 minutes (so long as you have jumper cables to use).
I'll also try this
T77911S 06-19-2019 04:09 AM
i would just take it to the parts store, most do it for free.
sugarwood 06-19-2019 04:55 AM
Yea, but why pass up the opportunity to buy a new tool?
It's weird how certain tools are never purchased by DIY'ers,
yet there are 100's of other tools they'll gladly buy and use once.
After 2 days on the charger, the battery measures 12.46v
I will do the other tests today.
T77911S 06-19-2019 11:48 AM
if you have a charging problem the parts store may be able to tell you if it is a diode or regulator or maybe something else.
otherwise its a crap shoot as to if it is the regulator or something in the alt unless you know what you are doing with a MM.
I am an electronics tech, also use to auto electric work along with rebuilding starters and alt's and even "I" will just take it and have it tested. its just too easy.
no its a cool tool.
I question his results on the alt being good when he put 100amps to it though.
it looked like the voltage dropped to around 10v(would have to go watch again) and un less he had a 70 amp or even 100amp alt on there I thought his reading was bad.
again, I would have to go watch to be sure.
sugarwood 06-19-2019 01:01 PM
Latest reading
12.5v but now at 13.7v while running
Gonna get it checked by the store now
911pcars 06-19-2019 01:18 PM
Can DIY a load test with a VOM or DMM. Hook up leads to the battery, then with the ign. disabled, crank the engine and see the voltage drop to some lower voltage. That's a poor man's load test.
If starting with a fully-charged battery at around 12.6-13 volts, during cranking, a good battery should be not less than 9.6V.
S
sugarwood 06-21-2019 06:35 PM
Car off 12.8v
Running 13.7v
Back on the road!
911pcars 06-21-2019 07:09 PM
Connect a battery maintainer when vehicle not used for days. The battery will appreciate that.
With your voltmeter, check battery voltage with all possible electrical loads ON. If the system charging rate is too low for the loads in use (low 12s), the battery will discharge and we will hear from you again. :)
S
sugarwood 06-24-2019 06:10 PM
Took a long drive today.
Pulled into the driveway, and measured voltage
Car running 13.5v
Car running with lights on 13.2v
Does the voltage go down when the battery is full ?
The battery cranks like it's at 100%.
pampadori 06-25-2019 05:36 AM
I still think your ground strap is the root cause.
Remember that I mentioned mine would show good charge at first but after a long drive the voltage would start to drop and drop until it was in the 12's.
dhanl82 06-25-2019 08:15 AM
battery
My 1982 SC with a new ground strap and a new alternator about 5K miles ago, usually has a measures engine running voltage of around 13.5, however it keeps the battery resting charge at 12.5 volts and I never have any issues. In addition, my voltage output with lights on is about like yours. I realize that the measured alternator voltage can be considered a bit low but, again, I have no issues.
Dave
Porsche 935 06-25-2019 08:28 AM
The more power (amps) being used the lower the voltage.
911pcars 06-25-2019 08:48 AM
Suggest measuring active voltage charge with the maximum number of anticipated electrical loads. That includes engine ON, fog and headlights (high beam), blower fan(s), window wipers and defrosters, sound equipment, etc. All put a load on the charging system which should support all these and at a level above battery recharging threshold.
Connect a voltmeter onto any convenient 12V source wire and observe the voltage level during vehicle operation.
S
ClickClickBoom 06-25-2019 02:31 PM
Car off 12.8v
Running 13.7v
Back on the road!
No worries. Batteries are boring but necessary.
sugarwood 04-02-2022 04:51 PM
For kicks, I tested my 911 today
Engine off = 12.9
Running = 14.1V
shoooo32 04-05-2022 08:20 AM
I run a battery tracker - it records battery voltage during startup and sends alerts to my phone when I'm within bluetooth range. My SC Targa voltage is 13.3 with the engine off, 12.8 during cranking and 14.3 at idle.
https://antigravitybatteries.com/products/accessories/battery/chargers/bluetooth-tracker-lithium/
sugarwood 09-26-2023 01:31 PM
My 2019 AGM battery is dead.
Last 4 years, I have not driven the car much and it mostly sits on a tender
I put it on a trickle charger overnight and still dead.
I removed the battery from the car and hooked up a 12V charger
Once charged, I will take it to FLAPS and load test.
If fail, I will get a new 48 battery for $200 regular or $250 AGM
EC900 09-26-2023 06:23 PM
Assuming the connections are clean and tight ...4 yrs on a battery is about the average life span, some last longer, some don’t. Doesn’t matter if the car in running or kept on charge.
For example I had a 4 yr old that read 12.4v and wouldn’t start my Harley which sat 5 months overwinter on a trickle charger.
Trickle charge overnight won’t fully revive a stone cold dead battery, you’ll need a lot more amperage. Bad battery cells might not charge more than 12.5v.
Heat kills batteries faster too and from overcharge. . Check the voltage output on your charger/maintainer too. I once thought my charger was plugged into the quick connect, I found socket pin was bad. Another older unit didn’t have a charging indicator light. Even the charger can go bad and could affect charging rate.
darrin 09-27-2023 07:02 AM
sugarwood -- what make/model tender were you using? How frequently do you drive your car? Asking, as I frequently let my car sit for a week or 2 at a time and don't use a tender (unless its sit for a month or so) -- my last 2 AGM batteries each lasted me over 6 years and wondering whether frequent battery tender use is slowly "cooking" your battery.
Having dealt with the very messy aftermath of an overcharging situation with my last non-agm battery (which boiled out onto the battery tray and components beneath the tray), I will never install another non-agm battery in my 911.
