Jbabic's Avatar
Oil line removal....ouch!!
Removed the old oil cooler and lines this week, and yes, tore off the threads on the thermostat....well I didnt' the dealer did. I took it to them so they could have the liability....then they charged me 1/2 hour and handed me back CRAP!.
anyhow, I have bought the Thermostat savers...hope they work, but can I save the threads on the lines? anyone? ANyone? Bueler?
Old 03-22-2003, 06:38 AM
getting that aluminum out of the threads of the line nuts is about impossible. you could try picking it out with an awl type tool, but it gets bonded to the steel and sometimes it's best to just replace the line. normally, the way to save the t/stat threads is to split the nut on the line, which would require line replacement anyway.
206 637 4071
Old 03-22-2003, 08:27 AM
Senior Member
Doug Zielke's Avatar
Remember to put some Nevr-Seize on all the threads when you re-assemble. What the damn factory should have done in the first place!
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 03-22-2003, 08:35 AM
Take out the thermostate, have the new saver welded on over the old fitting , and replace the line.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-22-2003, 09:10 AM
Early_S_Man's Avatar
Porsche Crest
You may want to try cleaning the nuts with imbedded aluminum threads thoroughly with degreaser ... then carefully suspend just the nut in a glass jar of Muriatic acid for a few minutes ... all of the cadmium plating (if still left) will be removed, but the acid will dissolve the aluminum and leave clean steel threads,too!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-22-2003, 09:17 AM
warren, you're kind of handy sometimes.
206 637 4071
Old 03-22-2003, 09:59 AM
Porsche Crest
Thanks, John!
Sometimes being 200 miles from 'civilization' out in the desert ... improves one's creativity ...
Warren Hall, Jr.
Old 03-22-2003, 10:02 AM
Jbabic's Avatar
Muriatic acid can be bought where? I will take a look at a local hardware store...thanks again!!
Old 03-22-2003, 04:01 PM
Any Pool supply house should have some... I think.
Neil
'73 911S targa
Old 03-22-2003, 04:04 PM
KTL KTL is offline
Schleprock
KTL's Avatar
You got it. Any decent hardware store should have it.
Warren rocks.
Kevin L
'86 Carrera "Larry"
Old 03-22-2003, 04:18 PM
