911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest outer springplate cover
Hi there,
Due to a little corrosion, I want to renew the outer springplate covers. Can I change them without disturbing rear wheel alignment and vehicle ride height?
#29
Thanks,
Kees.
Old 03-22-2003, 01:17 PM
Yes!
Old 03-22-2003, 01:44 PM
kees's Avatar
Porsche Crest
Thanks 2thdr
Old 03-22-2003, 01:56 PM
Not unless you have a lot of self control. Once you take off the cover you might find that the bushings look a little worn and then you'll want to do the swing arm bushings....
I started with a simple front brake rebuild, then I did the rears, then the master cylinder. Now I have replaced the the rear wheel bearings, new a-arm bushings, new spring plate bushings. Since I had a '73 with non-adjustable spring plates, I just had to get some used adjustable ones. And while I am there, I might as well upgrade the torsion bars....
Good luck. The Pelican part number is A-333-153-00 and they are a bargain at $14.95. I bought those too :-)
Neil
'73 911S targa
Old 03-22-2003, 02:20 PM
