LinkBack | Thread Tools | Rate Thread |
For those with upgraded AC systems, what should typical vent temps be?
My car is in for basic maintenance service and I'm having them service the AC while it's there. I've replaced the entire factory AC system with the Classic Auto Air kit.
What temperature should I expect to see from the center vents on high?
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car 1985 911 Carrera Coupe-Grand Prix White/Red |
I know that is where most people measure the temps. I can't get a thermometer to just hang there as I drive. Normal driving conditions is the real test. I had an 1985 Carrera, and the little bitty vent on the sides of the dash. I can slide a standard AC temp gauge in that as go for a drive. It will blow 38 to 40 degree air from that vent at full high speed blow on a 100 degree day. Even after stopping for lunch and the car sits in the sun for an hour. Get in, go and 15 minutes later that side vent is blowing cold. The center vents blow so much air with the upgraded fan kit I bought from Griffith's I have to divert it away from my face if I have it max cold and getting 38 to 40 degree air.
My ultimate winning moment was in Savannah, GA in August, full sunny day and stupid heat index. My wife asked me to turn the temperature up because she was cold on a lunch time trip. ![]() I have the four condenser Griffith's system, and the variable speed fan switch and his hurricane blower. His stuff is expensive, but top quality.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
i have his evap and front and rear cond,.
40's maybe 50. that's driving with fan on hi, BUT I have to turn the temp up because the evap will freeze over. people will say they get down in the 30;s or even 20's but a proper system should never get that cold BCAUSE of the evap freezing over and the low side pressures can get too low. the 911 does not monitor the low side like most cars do, they just use an evap temp probe to "control the low side" not the best way to do it. part of the reason you can get down to 30 is if you set the fan speed to low and/or the air flow over the evap is low, in part due to the low CFM out of the stock fan. you also need airflow over the condensers to get proper or accurate temps.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold Last edited by T77911S; 06-28-2019 at 06:37 AM.. |
Vintage Owner
It would be helpful to see what temps folks see with a properly functioning factory system in comparison.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Been here a while
a lot of folks measure with an IR/laser infrared thermometer. It simply won't be accurate. These things are designed to measure the temperature on a surface, not air temperature. Mine showed temps well below freezing, 20 degrees F at times. It was suffering from a thermal shock condition. Instead, I used an instant read analog kitchen thermometer in the center dash vent.
I've got the full Kuehl/Griffith's kit too, 4 condensers, the high efficiency evaporator, the upgraded fan/blower. Running R-134a, which won’t cool as well as R-12.....you’d be hard pressed to get R-134a to give dash temps below 40 degrees, in even a modern car. From my in-dash thermometer I get temps right around 40 degrees, occasionally a 39, most often a 41-42, fan on high, car in motion, system running for a few minutes or a few hours. Lots of compromises here, and I’m sure lots of variables in terms of how temps are being measured, ambient temp, relative humidity, choice of refrigerant, methods of measuring temps.
looking for 1972 911t motor XR584, S/N 6121622 Last edited by blucille; 06-29-2019 at 05:31 AM.. |
Flat Six
For a point of reference, my stock (r134a conversion, ND compressor, factory condensers & evap) runs 48-50 degrees at the center vent w/fan on high and car in motion. That's with a fresh charge and ambient temps here in the LV valley at low triple-digits right now.
Dale 1985 Carrera 3.2 2013 Audi Q5 2.0T / 2005 BMW 325ci |
Try contacting Charlie at https://griffiths.com/porsche/air-conditioning/ one of the best sources for 911 AC info.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Mighty Meatlocker Turbo
It's always good for a laugh to see posts from peeps who apparently can not build a genuinely cold a/c system so then declare that it is either not possible, performance testing is flawed, or it is actually a negative to have super low vent temps. I heart Pelican a/c threads!
I have the full Griffith upgrade and can get sub 40 temps on a hot day with the middle fan speed. Using his improved performance evaporator fan the temps do increase slightly with the higher fan speed.
Walt 82SC 3.0 81SC 3.6 |
My other ride is a C-130J
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
I thought of you when I posted that (#forum bromance), as there are several members (not like THAT! ![]() |
If your evaporator is freezing up, your temp probe is not properly located. I just this spring put in Griffiths bigger blower. When I put the probe back in I made sure it was properly located, and I used a small dab of thermal paste. I have his variable speed fan switch as well, and that comes with s LED that indicates if the compressor is running. I can see the temps get down to high 30s and the compressor kicks off. No more freeze up. Before I could get freeze up, but I just dialed the temp back and kept it from freezing. I figure either way if the evap is just above freezing, it is max cold.
I don’t sustain meat locker temperatures as long as Rawknees, his system is better designed. ![]()
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 06-28-2019 at 01:43 PM.. |
I have replaced all my a/c components except the rear condenser and added a Griffins rear fender condenser. I use r12 Freon and it blows 29 degrees on a 90 degree day. Do your self a favor and find some r12
If you are running R134A and it is 100F ambient, then any AC pressure chart will show a typical low side pressure of between 50 and 50 PSI. If you cross reference that pressure with the boiling point of R134A you will find that the boiling point is in the range 45 to 51F. That’s inside the evaporator. You will lose some of that in exchange with the air and on the way to the vent.
Some people are either defying physics or not running R134A or perhaps....
www.classicretrofit.com |
What's a reasonable vent temp for modern car? I'm redoing my 86 Carrera AC and was curious what vent temps should I shoot for? So I drove my 2018 Buick Regal Tourx around Austin today with a thermometer stuck in the vent. Outside temp was in the mid 80's and vent temp was between 43 and 45 consistently. It's got that shut-off at a light feature and temps would hit 60 until I was under way.
1973 911T Sepia Brown MFI 1986 Carrera Meteor Gray Metallic |
^ mid 80s would be a pressure of ~40 PSI corresponding to a boiling point of ~45F. So pretty much exactly your readings.
Normal cars seem to adhere to the rules of the Universe. ![]()
Burnin' Rubber
Yes, we all wuv AC threads...
I’ll throw this one in to the pile: Forget r-134 and r12 Try industrial grade Enviro-safe. Colder than r12! Significantly less pressure on the compressor! Ok, I’m eating popcorn and I’ve bookmarked this thread ![]() |
