Long pedal after new calipers- multiple bleeds
Replaced all 4 calipers (nice "new" calipers from Eric) and pads on my '72 T targa. Even after multiple bleeds with Motive and another with a friend the old fashioned way, still have a really long pedal with horrible feel. Not getting any air out but pedal won't firm up. Pedal feel was great before I started...
I've been doing this for 40+ years but what am I missing????
1971 914- original owner
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 07-07-2019, 10:27 PM
Functionista
manbridge 74's Avatar
Take the pads out and put a thin shim on each side. Press pedal a few times. Remove shims and move pistons back just enough to put (actually force) pads back in. Bleed as usual and again a day later. Search “exercising caliper pistons” for more info..
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-07-2019, 10:32 PM
Bill Douglas's Avatar
Unlikely...
But this is what I did :blush: I put the calipers on upside down. They fitted up fine and worked OK, just a bit spongy. Being upside down the air wasn't floating upwards and out the bleeders.
Good luck with finding the solution.
Old 07-08-2019, 12:55 AM
Vulnerari Praesidio
Firmly tap (HIT) the caliper several times with a wrench while you are bleeding. Helps to move the air bubbles out of the caliper.
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 07-08-2019, 04:40 AM
Diss Member
Quicksilver's Avatar
It isn't unusual for it to take a while for the seal retraction to take a while to settle down but Eric's would be the least problematic calipers available.
The question is if the problem is a caliper or farther upstream in the system.
I'd put the car up on stands and use a caliper (machinists caliper) to measure the travel of the pads on each wheel. If one is noticeable longer you have something to chase down.
If they are all the same you can look at lines and the master cylinder.
Test, test, test!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-08-2019, 05:14 AM
When you removed the calipers, did you remove them one at a time, or did you replace them all at once? If all of the fluid ran out, you might have to bench bleed the master cylinder.
Old 07-08-2019, 07:21 AM
Vintage Owner
Jack Stands's Avatar
I found that taking the car out for a drive on some bumpy roads while the pedal was still less than optimum helped to shake the air bubbles up to the bleeders. One more bleeding operation (I seem to remember I used a pressure bleeder that time), and the pedal became wonderfully firm.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 07-08-2019, 08:32 AM
U...I put the calipers on upside down. They fitted up fine and worked OK, just a bit spongy. Being upside down the air wasn't floating upwards and out the bleeders.
9 times out of 10, this is the problem. If your bleeder valves are pointing to the ground instead of the sky, this is your issue. Simply swap left to right and rebleed.
True story: My neighbors rebuilt his calipers on a 914-6 and went through a gallon of brake fluid without getting firm pedal. I came over to assist and noticed his bleeder valves pointed down instead of up. We swapped sides, and it firmed right up. He was not amused with himself.
Funny thing is the very next weekend, Car Talk had a puzzle that is exactly like that. I called the neighbor up and told him to call in to Car Talk to solve the puzzle.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-08-2019, 08:47 AM
theiceman's Avatar
Test, test, test!
this ...
go out and bed the brakes,,, long travel will go away quickly.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-08-2019, 08:56 AM
Just talked with Eric and it's probably the new seals retracting the pistons. He mentions this in his FAQ section of his website... Need to bed the pads and seals and get everything hot- not a problem here in Scottsdale this time of year!
Will drive the car though I hate a long pedal!!
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 07-08-2019, 10:03 AM
Diss Member
Imagine a 2000 mile road trip with a "pump it every time" pedal.
When I got home I called Eric to get good rebuilt calipers...
__________________________________________________ _____
BTW - To anyone who doesn't know: The "Eric" we are all referring to is Eric at PMB.
Old 07-08-2019, 11:57 AM
Jameel's Avatar
Ditto on what Jeff said. It's also what Eric told me to do on mine when I asked him at Rennsport last year. Try it. It worked for me.
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 07-08-2019, 12:14 PM
VFR750's Avatar
This is a very typical result of a rebuild. The seal retracts the piston too much.
Do this process and you will at least addressed the most common problem after a rebuild.
Old 07-08-2019, 12:19 PM
