Electrical Issue
I have a 1971 911T targa. Car has been great for a long time. After a long run last Sunday, the car sat until Friday, when I was about to go to a show. Turn key, nothing happens. No lights! No crank nothing. Check battery, OK. Kept jiggling key and most of the time nothing, but occasionally red light came on and I could turn on radio. At times gauges would flick on. But never lights, parking or dim. Press emergency flasher and sometimes a noise behind dash.
I am thinking ignition switch. Any ideas? I appreciate any feedback. Best wishes, John Last edited by irishgreentarga; 07-20-2019 at 05:00 PM.. |
ROW '78 911 Targa
Check the 6 pin plugs under the dash are all fully seated.
If the same as my 69', check fuse position 1; the fuse, fuse holder and most importantly the screw clamps for the source (battery) wire on one side and the ignition switch circuit on the other side. If an open circuit appears here, power distribution is nil.
A voltmeter would be a handy tool to check for available voltage and/or where it stops abnormally. Sherwood |
ROW '78 911 Targa
‘70 is a direct run from the battery to the 6 pin connector and then to the switch.
Check for loose battery positive terminals on the 3 reds going to it.
ROW '78 911 Targa
First post since joining in 2012!
Customary to post a picture of your car.
Thank you for your suggestions!
Hi folks -- I will follow through on your suggestions tomorrow, once this very hot weather in Ohio breaks, I will let you know what I find out.
![]() Note that structure in the photo background is not mine! |
I'll get to them as soon as it rolls down, probably Monday. Attached is a photo of the car. Note that I do not own the structure in the background!
ROW '78 911 Targa
Beautiful looking targa.
Let us know what you find out.
did you clean the battery terminals first
