Electrical Issue
I have a 1971 911T targa. Car has been great for a long time. After a long run last Sunday, the car sat until Friday, when I was about to go to a show. Turn key, nothing happens. No lights! No crank nothing. Check battery, OK. Kept jiggling key and most of the time nothing, but occasionally red light came on and I could turn on radio. At times gauges would flick on. But never lights, parking or dim. Press emergency flasher and sometimes a noise behind dash.
I am thinking ignition switch. Any ideas? I appreciate any feedback.
Best wishes,
John
Old 07-20-2019, 04:48 PM
ROW '78 911 Targa
timmy2's Avatar
Check the 6 pin plugs under the dash are all fully seated.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-20-2019, 05:14 PM
If the same as my 69', check fuse position 1; the fuse, fuse holder and most importantly the screw clamps for the source (battery) wire on one side and the ignition switch circuit on the other side. If an open circuit appears here, power distribution is nil.
A voltmeter would be a handy tool to check for available voltage and/or where it stops abnormally.
Sherwood
Old 07-20-2019, 06:16 PM
ROW '78 911 Targa
timmy2's Avatar
‘70 is a direct run from the battery to the 6 pin connector and then to the switch.
Check for loose battery positive terminals on the 3 reds going to it.
Dennis
Old 07-20-2019, 06:26 PM
ROW '78 911 Targa
timmy2's Avatar
First post since joining in 2012!
Customary to post a picture of your car.
Dennis
Old 07-20-2019, 08:03 PM
Thank you for your suggestions!
Hi folks -- I will follow through on your suggestions tomorrow, once this very hot weather in Ohio breaks, I will let you know what I find out.
Note that structure in the photo background is not mine!
Old 07-21-2019, 05:16 AM
Talking Thank you for your suggestions!
I'll get to them as soon as it rolls down, probably Monday. Attached is a photo of the car. Note that I do not own the structure in the background!
Old 07-21-2019, 08:49 AM
ROW '78 911 Targa
timmy2's Avatar
Beautiful looking targa.
Let us know what you find out.
Dennis
Old 07-21-2019, 08:58 AM
T77911S's Avatar
did you clean the battery terminals first
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-23-2019, 04:40 AM
