leaking air box
Guys:
Pardon me for a very novice question. Can a compromised (deformed due to heat) thus leaking air filter box on a 3.2 Carrera cause serious mixture deviation? If so, more likely to be too rich or too lean?
(I know, very basic..)
Old 07-18-2019, 09:09 AM
on a 3.2 motronic, the air filter box is upstream of where the AFM meters airflow -- so it air leaking around the air filter on a 3.2 shouldn't cause any mixture issues (on my 911 the airbox has been replaced with a cone filter w/o issue).
on a CIS engine, otoh, the airbox is sealed and a leak, etc. will affect mixture.
if you're suffering from mixture issues, I'd look downstream of the AFM for issues
Old 07-18-2019, 09:43 AM
Let me be more specific. I just changed spark plugs. Cylinder 1 seems to have firing issue, plug is all black and oily. Changed ignition wire 1-3 hoping to fix firing issue. Started car, at first extremely smooth and normal. After about 2 minutes, idle starts to unstabalize. exhaust starts to smell irritating. Feels like mixture confusion.
Old 07-18-2019, 09:47 AM
Thanks Darrin, that makes sense!
Old 07-18-2019, 09:48 AM
no problem -- If limited to cylinder 1, I'd start by checking the intake manifold to confirm it's tightly attached and leak-free. Also, what's your oil consumption like? black/oily could indicate bad valve guide?
Old 07-18-2019, 09:54 AM
ROW '78 911 Targa
timmy2's Avatar
Slipped intake gasket? According to John Walker fairly common.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-18-2019, 10:13 AM
Thanks Timmy2! I will also look into that.
Old 07-18-2019, 04:35 PM
