Help--my decklid won't open
I put my ducktail on last week and now the da*n thing won't open! What can I do? Any tricks? I need to take the car in for some work on the starter and get it prepped for a DE coming up too.
1980 911SC Targa 3.6L |
Just a thought get a helper and while pulling the cable have your helper gently push down and or pull up the lid .
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
There is a recent thread on this topic if you search. I had a similar experience with an aftermarket decklid, and the advice was all over the place. Nothing worked for me, short of cutting a hole in the panel directly beneath the latch, and levering the pin slightly with a screwdriver while someone pulled on the cable. Once released, we found that the latch was adjusted too far rearward, and ended up having to grind out the slots for the bolts slightly to get more adjustment.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
The pin is hanging due to misalignment.
Try pushing the lid side-to-side while someone pulls the handle. You may also slide a putty knife in and push the pin around enough to free it.
Chuck Moreland - elephantracing.com - vonnen.com |
