Rear torsion bar install- spring plate cap popped off...
Hi,
I tried to put my rear suspension back together and encountered a little problem. One of the spring plate caps popped off.
It appears as if one of the torsion bars was not completely seated so when I started tightening down the torsion bar covers, the cap popped off to reveal a nice torsion bar. Does the collective wisdom of the board think I can gently hammer the torsion bar back into the car or should I take everything apart?
There is about a 1 inch gap between the spring plate cover and the end of the studs where the cover should rest.
I wanted to start hammering away, but I didn't think that my neighbors would appreciate it at 11PM.
Neil
'73 911S targa
Old 03-24-2003, 08:43 PM
trak ratt's Avatar
As long as the torsion bar splines are engaged on the inside of the torsion tube no problem. I’d use a plastic hammer or at least a piece of wood so you don’t mash the end of the bar. If the cap doesn’t fit firmly get a plastic pipe end cap to keep the dirt out of the spring plate.
Old 03-25-2003, 03:07 AM
David,
Thanks for the advice. I hope I don't have to take it apart. I have both torsion bars indexed at the same angle, plus I don't want to have to unbolt the cap.
Does anybody make an electric ratchet wrench?
Neil
'73 911S targa
Old 03-25-2003, 10:06 AM
trak ratt's Avatar
Not that I know of but you can buy a “speed handle” for very little. Those 8 bolts can get tiring! Just wait & see how you feel about them if you didn’t index the torsion bars correctly the first time!
Some cause happiness wherever they go; others whenever they go.
Old 03-25-2003, 10:15 AM
makaio's Avatar
I haven't seen an electric ratchet wrench yet. But what I do when I have alot of fastners to remove is use my electric screw gun(drill), with a 3/8" adapter to put sockets on it. Works great after the fastners have been broken loose.
Old 03-25-2003, 10:17 AM
Tell me about it. I was tightening the cover for the first torsion bar that I set when I realised that I forgot to included the car's angle when on jackstands.
I have used my drill before, unfortunately there is not enough space to get between the fender and the body.
I can't wait to get everything back together and see how it looks. Having used Wil Ferch and Thom Fitzpatrick's spring plate calculator, I am hoping that everything will line up on the first shot.
Neil
'73 911S targa
Old 03-25-2003, 10:44 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Neilk,
Let us know how the calculator worked out for you. I'm going to be doing the same shortly.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 03-25-2003, 11:11 AM
