Dave Ploss's Avatar
Cool Fr Suspension Install- Loctite vs anti-Seize?
Everything is off thefront end....A-Arms, Arm covers and belly pan have been POR 15'd. Struts are clean.
On the re-assembly...where should I use loctite and where should I use anti-seize. Some procedures give suggestions but I would like to know the "philosophy" of when to use these.
Calipers will be painted next weekend along with the A/C condenser cover and protection bar.
Thanks.
Dave
Dave Ploss
'87 911 Carrera Coupe - Black
'90 Mercedes 190E
'00 Filippi Lightweight Double
Old 03-25-2003, 08:34 AM
IROC's Avatar
The simple answer is use anti-seize in locations where you want to take things back apart (like for routine maintenance) and especially in locations of dissimilar metals. Caliper bolts is a good example. Use Loctite where you don't want things to come apart unexpectedly. I actually don't use Loctite on anything unless it *specifically* says to.
Anti-seize is your friend. :>)
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-25-2003, 08:50 AM
Dave Ploss's Avatar
Castle Nut?
I know they suggest anti-seize on the wedge bolt itself, not the threads. How about the castle nut on the ball joint. To do work on the suspension, either the castle nut or the wedge bolt has to come out most of the time.
The castle nut has the locking washer.
Dave
Dave Ploss
'90 Mercedes 190E
Old 03-25-2003, 09:13 AM
IROC's Avatar
As long as you're torquing everything correctly, using anti-seize isn't going to hurt a thing. When in doubt, I'd use it.
Mike
Mike
1976 Euro 911
Old 03-25-2003, 09:28 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Use antiseize on the notched nut for the ball joint, the wedge pin for the ball joint & strut bottom, all of the bolts that hold the A-arms to the car, wheel studs and caliper bolts (use new spring washers).
Use blue loctite on the tie rod ends going into the steering rack (not at the knuckle- has a cotter pin).
The four cotter pins you'll replace (two for the tie rods and two for the protective covers on the ball joints) are metric. I found that English/SAE sized pins didn't fit too well. Good source for metric cotter pins is McMaster-Carr (www.mcmaster.com). Good hardware and fast service. Got my stuff in one day. Helps when the have a warehouse location in your state..........
Kevin L
'86 Carrera "Larry"
Old 03-25-2003, 10:31 AM
Dave Ploss's Avatar
Kevin,
Thanks...that's what I was planning. I guess that, if it's going to come apart later, anti seize. If you want to make sure it doesn't wiggle loose, loctite. I put blue loctite on the tie rods when I put them in the steering rack.
Guys, Thanks so much.
Dave
Dave Ploss
'90 Mercedes 190E
Old 03-25-2003, 11:25 AM
