7783911's Avatar
RE WIRE Fogs
I was thinking about replacing enemic fog lamps with a pair of Marchels and would like to determine how to wire to a separate switch on dash with relays..any ideas on what pickups to use on fuse board (1977 porsche 911). I understand i can re-route from light switch but its frankly a pita to get to that switch and to the actual fog lamp pull knob which is buried behind stereo and amp tucked up under dash. I can use a simple toggle (lit when active) in one of the spare dash holes which i can reach easier
Old 08-08-2019, 03:15 AM
Formerly known as Syzygy
Canada Kev's Avatar
There's no reason I can see that you can't use your factory switch that's already on your dash. As well, I believe that the original fog light circuit already runs through a relay, at least my '87 does, but I'm pretty confident yours will as well.
Kevin
Old 08-08-2019, 04:12 AM
7783911's Avatar
The original switch is virtually imp[ossible to access bacuse of other items in the way and its fed by the light switch on the 77... i would just run a new circuit with a relay
Old 08-08-2019, 07:12 AM
ROW '78 911 Targa
timmy2's Avatar
You already have all the wiring needed with a relay if you have original fog lamps and they turn on.
Just change the lamps.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-08-2019, 07:35 AM
7783911's Avatar
not sure i follow, from what i can tell i dont see any relay unless its built into the fuse panel?
Old 08-08-2019, 07:41 AM
ROW '78 911 Targa
timmy2's Avatar
Relay bases are mounted In the fuse panel.
J-5 in the drawing is the relay.
Dennis
Old 08-08-2019, 08:05 AM
cycling has-been
bkreigsr's Avatar
I thought you meant 'retire' - as in, get rid of.
Bill K
Old 08-08-2019, 09:06 AM
7783911's Avatar
typo, "rewire"
Old 08-08-2019, 09:08 AM
