Another won't start question
I took my car on a road trip this weekend--around 750 miles round trip. Everything was going fine until my drive home when after about 3 hrs on the road I pull in to refuel and when I turn the key nothing happens. There seems to be enough juice to run the oil aux fan and windows, lights, etc but the engine wont even turn. I ended up roll starting it and it ran fine the remainder of the trip home but now the car is in my garage and won't start again. Battery seems to be fine. Is there something in the starter that may have overheated? Thanks
1980 911SC Targa 3.6L
Old 03-25-2003, 02:05 PM
Check flexible ground strap from body to transmission (underneath on passemger side at front of transmission); starter gets it's ground through this strap. Also solenoid or Bendix mechanism on starter could be worn and dry (lubricant gone) so they stick when hot. Also brushes in starter motor could have failed. If starter won't turn over when cold I'd check connections (hot lead and ground strap) then suspect the brushes. Good luck, Jim
Old 03-25-2003, 03:41 PM
targa911man's Avatar
Jon--
Sounds like a typical hot-start problem. I had the same problem, but it seems to have been cured with a new starter. But don't start there. Do a search on the board and you'll find plenty of info. Pelican and others sell a bypass relay kit (I think it's Bosch WR-1, about $15)) for the starter that can get around the problem in many cases. Opinions vary on whether this is a cure or a stop-gap measure. I assume you've got a DME unit with the 3.6, so you might also try a new DME relay ($40). Many of us post-SC guys carry an extra DME relay because many starting problems can be traced to its failure. Good luck.
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 03-26-2003, 08:00 AM
Do a search on the starter solenoid, much has been written on the subject.
Joe
Old 03-27-2003, 05:44 PM
Clean and check all your battery and starter and ground connections first.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-27-2003, 06:53 PM
stormcrow's Avatar
Mine did the same thing last year on my way home from SC Motorsports. Shut the engine off to gas up and it wouldn't start. Roll started it and got it home - started everytime until just last week.
This weekend I am going to get in there and find out what's going on. BTW, after I tried starting it for about 10 minutes or so, it started. Go figure. Sounds like there may be a loose connection.
"A Porsche does more then just go fast in a straight line"
SteveKJR
Proud Owner of a 78 911 SC Targa
Old 03-27-2003, 07:45 PM
Buy them, sell them
Adam's Avatar
If the starter solenoid is flukey, then giving it 10-20 minutes to cool can sometimes cure the problem. I had a similar problem on my 535i, whilst driving it to College. These sort of problems manifest on a long trip where you can get some serious heat into the starter. A gentle tap with a metallic object can usually prime the solenoid into position to allow the car to start. I carried around half a star picket in the boot for such an occasion, since the problem was very intermittant.
It's very uncool to pop the hood and hammer the starter motor with a large steel pole on campus. Ask me how I know...
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 03-27-2003, 08:32 PM
