-   -   [BUILD THREAD] The 69 911s Blasphemy Build - LASTERN (http://forums.pelicanparts.com/porsche-911-technical-forum/1037129-build-thread-69-911s-blasphemy-build-lastern.html)
Trackrash 12-06-2019 09:30 AM
What dimension are you looking for? The problem is when I post a jpg, Pelican shrinks the picture. Maybe someone can link to a better file. For example this is 3264 pix wide on my computer.
http://forums.pelicanparts.com/uploa...1575656983.jpg
rennch 12-06-2019 09:32 AM
Can you email it? 2syllableword at gmail.
jpnovak 12-06-2019 09:54 AM
Those look like non-turbo trailing arms that have been relocated rearward and upward at the forward pickup point due to new mounting brackets.
You will likely find it easier to relocate the flare opening than to undo all that custom suspension fab work.
IMO the longer wheel base by moving rear wheels back is a GOOD thing.
Coastr 12-06-2019 10:11 AM
Either way you’re in for some work to get that wheel in the right place.
rennch 12-06-2019 10:13 AM
That’s the truth!
Coastr 12-06-2019 10:14 AM
If you’re going to fit new flared arches for wider tyres then maybe you can push those backwards and fill in the rest?. You can fill in the torsion bar hole while you’re at it.
jpnovak 12-06-2019 10:30 AM
Leave the torsion bar hole. Cut the QP behind the torsion bar hole. Offset cut the new flare and then slide it back. Plenty of metal to make up one inch there. Challenge will really be aligning the curvature of the top of the QP/flare.
Trackrash 12-06-2019 03:34 PM
Let's try again.
http://forums.pelicanparts.com/uploa...1575678851.jpg
rennch 12-06-2019 08:17 PM
Originally Posted by Trackrash (Post 10680719)
Thank you! I might need to order the real copy of this! Do you have a higher resolution version you might be able to email me? I sent you the email in an above message.
rennch 12-06-2019 08:18 PM
New YouTube video is live! Replacing quarter panels on your 911:
https://youtu.be/qycXDigWHEA
rennch 03-25-2020 05:07 PM
Hey dudes. I have two new videos. One comes out tomorrow.
My latest video about the abandoned 1969 Porsche 911s race car that I'm converting back into a street car. This video is about fitting and installing the rear decklid latch panel, but first I have to cut and grind away the race-modified rear engine quick release mounts. This is the 6th video in the series, so if you're looking for some cool Porsche content to binge on, now's your chance.
Latch Panel, video 1: https://www.youtube.com/watch?v=EejDXRjhu_g
And here's the link to the whole playlist: https://www.youtube.com/playlist?list=PLpd6y-3BC1Z4BJ4KQ36wQDshyliZHyYfM
rennch 03-27-2020 07:35 AM
Part 2 of my rear latch panel fabrication and install is posted on YouTube: https://youtu.be/ZmAgqKuW0CM
drb930 03-27-2020 08:55 AM
The 993 is the same WB as any 69-89 911. WB was not increased until 996.
RUF has a 993 that they have pushed the front wheels forward, and the rear wheels rearward.
The article is here - https://www.excellence-mag.com/issues/240/articles/200-mph-classics
He gets the arches correct and it makes the car look much more modern.
Might be some inspiration for your rear arches.
BTW really enjoy your videos.
Are you going SBC V-8?
drb930 03-27-2020 09:33 AM
Here’s a picture of the 2 WB’s, Orange car is the longer WB.
http://forums.pelicanparts.com/uploa...1585330315.jpg
rennch 03-30-2020 07:28 PM
No...at the moment I'm trying to decide between two powerplants. One is Japanese, and one is Porsche. They are both flat 6's though.
rennch 04-01-2020 05:39 PM
Passenger Quarter Panel Install
I got my passenger quarter panel trimmed pretty darn close. Am curious about the door gap. Can I dial it in with a little hammer/dolly on the inside if I want to move it a millimeter or two?
Here's the video of the process/install:
https://youtu.be/vuqPQLhaorA
Some Pics:
http://forums.pelicanparts.com/uploa...1585791506.jpg
rennch 04-01-2020 05:40 PM
Also..I'm not exactly sure what to do about the existing lead filler. I may need to delete some of it so I can get to the metal to weld it. On the grey ghost, I hit it with a propane torch and it melted away. I'm planning on doing lead filler on this car for the drip rail delete, so I could probably do it here as well.
rennch 04-01-2020 07:32 PM
Cleaned up the welding interfaces.
https://uploads.tapatalk-cdn.com/202...883e47021b.jpg
https://uploads.tapatalk-cdn.com/202...0dd654bd74.jpg
https://uploads.tapatalk-cdn.com/202...6d502258d9.jpg
rennch 04-02-2020 12:24 AM
Here's the full playlist from the beginning, now that I know how to properly embed the vids:
Video 1, the unveiling:
<iframe width="560" height="315" src="https://www.youtube.com/embed/mfrbo3ohBlg" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-02-2020 12:27 AM
Removing More Race Car Bits:
<iframe width="560" height="315" src="https://www.youtube.com/embed/V7EZEXq2MTo" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Project Outline and plan:
<iframe width="560" height="315" src="https://www.youtube.com/embed/IlWKtN_cjYc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-02-2020 12:28 AM
Front Bumper Rust Repair and cutting into the custom race "nose" of the car to fit the front fenders.
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZLvwYRaIHsc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-02-2020 12:33 AM
The Restoration Design panels have arrived! Initial fit of the rear quarters, and stripping off some of the race bits to make them work.
<iframe width="560" height="315" src="https://www.youtube.com/embed/qycXDigWHEA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-02-2020 12:34 AM
Rear Panel Install Part 1!
<iframe width="560" height="315" src="https://www.youtube.com/embed/EejDXRjhu_g" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Rear Latch Panel Part 2!
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZmAgqKuW0CM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-02-2020 12:35 AM
Final Quarter Panel Fitment, Passenger Side!
<iframe width="560" height="315" src="https://www.youtube.com/embed/vuqPQLhaorA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-02-2020 07:19 AM
Finished off with some weld thru primer today.
https://uploads.tapatalk-cdn.com/202...10ac6fe86d.jpg
https://uploads.tapatalk-cdn.com/202...49072d7cf1.jpg
https://uploads.tapatalk-cdn.com/202...40a763fc92.jpg
https://uploads.tapatalk-cdn.com/202...ae758a989d.jpg
https://uploads.tapatalk-cdn.com/202...ca284fb527.jpg
Cory M 04-02-2020 09:42 AM
You don't want to put plastic filler over the lead. So you'll either need to remove it with a torch or use lead filler.
rennch 04-02-2020 10:25 AM
Yea...that's what I was thinking too. Plus I want to learn lead filling...I think it's a lost art.
Zeke 04-08-2020 10:05 AM
I just saw this car in person and it's the real deal although I don't envy the amount of work ahead.
And money.
But if it turns out to be close to the concept it will be a world class build.
http://forums.pelicanparts.com/uploa...1569462463.jpg
rennch 04-08-2020 10:26 AM
And money.
Thanks Milt. Nice seeing you IRL (we kept 6 feet apart).
I'm hoping because it's going to be mostly DIY that it won't be a tremendous amount of money. Famous last words.
rennch 04-22-2020 06:58 PM
I've just uploaded the latest video of my 69 911S Blasphemy Build, where I try to figure out if I can use my flux core welder to patch some unseen body panels.
<iframe width="560" height="315" src="https://www.youtube.com/embed/zlNojShBudQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-25-2020 11:35 PM
Posted another video today wrapping up the fabrication and install of the passenger side kidney piece, and rocker panel patches.
I coated the inside with POR15 (thanks Zeke) and then finished it off with my signature pigeon poop welds.
First I used my propane torch to burn off the lead filler and give me something solid to weld on.
I made a couple of rust repair panels and was able to weld them on before grinding everything down and coating it with POR15.
https://uploads.tapatalk-cdn.com/202...fb1f700ea9.jpg
https://uploads.tapatalk-cdn.com/202...92904bce9f.jpg
https://uploads.tapatalk-cdn.com/202...ae30590f4a.jpg
https://uploads.tapatalk-cdn.com/202...2e30180ec5.jpg
https://uploads.tapatalk-cdn.com/202...107d557ad2.jpg
https://uploads.tapatalk-cdn.com/202...79e9a9092d.jpg
https://uploads.tapatalk-cdn.com/202...d0943b7dc4.jpg
https://uploads.tapatalk-cdn.com/202...b152a988ee.jpg
https://uploads.tapatalk-cdn.com/202...a7f43e5e23.jpg
rennch 04-25-2020 11:46 PM
If you prefer the video...
<iframe width="560" height="315" src="https://www.youtube.com/embed/6RLoCRr3F8U" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 04-29-2020 10:39 AM
Today I tackled more chassis restoration, and I had to use a bottle jack to spread my rear frame rails! The full roll cage of this car had "compressed" the frame rails a few mm, and my replacement panel from Restoration Design was a good 1/2" off from being able to be installed.
This was the jack I eventually used, with a 2x4 against the opposite frame rail.
http://forums.pelicanparts.com/uploa...1588184504.jpg
I was able to use one of my regular floor jacks as a "proof of concept" and got the piece in for measurement.
Quick test fit of the outer rear latch panel piece.
rennch 04-29-2020 10:40 AM
After welding it on and cleaning up the welds.
http://forums.pelicanparts.com/uploa...1588185316.jpg
Then sealed up with a bit of POR15 as a stage 1.
Am excited to get that rear panel on so I can finally fit the quarters.
If you want to see the video of this whole process, here it is:
<iframe width="560" height="315" src="https://www.youtube.com/embed/9bfvl7jyTX4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 05-17-2020 04:25 PM
I'm just about to fully weld up my quarter panels and rear latch panel. I am borrowing a stock set of right and left bumpers to help dial in my alignment, but I'm curious what the general procedure is for ensuring panel gaps, especially around the doors, are spot on.
Here's where I am at the mo:
http://forums.pelicanparts.com/uploa...1589761335.jpg
My plan is to use lead filler where the factory did, but I'm most concerned, like I said, about panel gaps. What are the techniques to dial in my door gaps correctly?
rennch 05-18-2020 01:39 PM
Just uploaded a video on my quarter panel install!
<iframe width="560" height="315" src="https://www.youtube.com/embed/POAazO2NVjA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
75 911s 05-19-2020 05:34 AM
Great job Michael. Your perseverance is paying off. It's starting to look like a car again.
coomo 05-19-2020 02:31 PM
You need to hang doors before permanently welding outer sills(rockers) The whole shell fitment really revolves around door pillars.if you can get door fitting flush, this will help with rocker fitment.I once made error of fitting rockers (not 911) that sat so proud of door I had to cut them off and start again.Get the doors as close as you can then its shims, and hammers jammed in hinges.
