-   -   [BUILD THREAD] The 69 911s Blasphemy Build - LASTERN (http://forums.pelicanparts.com/porsche-911-technical-forum/1037129-build-thread-69-911s-blasphemy-build-lastern.html)
rennch 06-13-2020 11:33 AM
Latest video is up! I got the rear latch panel fully welded on, and came up with (what I think is...) an innovation as far as flaring the car!
Would love some input on the best methods to preserve door gaps. Is there a gap tool? spacers? Is it 3mm on a porsche?
<iframe width="560" height="315" src="https://www.youtube.com/embed/Pa4sbo3Ey9o" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 06-13-2020 11:36 AM
Originally Posted by coomo (Post 10871990)
You need to hang doors before permanently welding outer sills(rockers) The whole shell fitment really revolves around door pillars.if you can get door fitting flush, this will help with rocker fitment.I once made error of fitting rockers (not 911) that sat so proud of door I had to cut them off and start again.Get the doors as close as you can then its shims, and hammers jammed in hinges.
I'm not removing the rockers, so I should be relatively safe there.
rennch 06-23-2020 10:58 AM
I finally welded on the quarter panels on this 69 911 S. If I’m being honest… It was a bit terrifying. But, I made a jig to ensure the panels were in the correct location before I welded:
https://uploads.tapatalk-cdn.com/202...3e3a14cd9b.jpg
rennch 06-23-2020 10:59 AM
Here's the full video:
<iframe width="560" height="315" src="https://www.youtube.com/embed/WFta1LDCD5U" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 06-23-2020 11:08 AM
Here’s where I started, just for reference:
https://uploads.tapatalk-cdn.com/202...7bbec824e9.jpg
https://uploads.tapatalk-cdn.com/202...5fd999d0d2.jpg
https://uploads.tapatalk-cdn.com/202...883c1417b9.jpg
Literally no rear of the chassis. It all had to be rebuilt from scratch.
https://uploads.tapatalk-cdn.com/202...fcfad59bca.jpg
https://uploads.tapatalk-cdn.com/202...e8a7c8c1fd.jpg
https://uploads.tapatalk-cdn.com/202...cacd6ebc5a.jpg
https://uploads.tapatalk-cdn.com/202...cc03e18b7a.jpg
It’s funny… Years ago people would kill for a video documenting all of this, but it seems like on pelican people don’t have quite as much interest in video as they do the photos, which is a little baffling to me. That said, I’m going to keep posting and documenting it because I think it’s important.
rennch 06-23-2020 09:48 PM
Crickets.
Saadi996tt 06-23-2020 10:05 PM
I’m following along, keep documenting/posting. The new place in Long Beach is way way bigger than your last location. Can’t believe you found a 4 car garage in LB.
ToySnakePMC 06-24-2020 03:49 AM
I’ve enjoyed the videos that I’ve seen so far. Great job and what a unique undertaking. I need to get caught up on the more recent ones. This will be a great hot rod when done.
Cory M 06-24-2020 08:43 AM
Looking good, way to dive in head first.
rennch 06-24-2020 05:23 PM
I know dude. It's a complete unicorn of a place. I have the paint for the other side of the floor, so that's on the list pretty soon.
rennch 06-24-2020 05:24 PM
I think it will! going to get the front end together next, then work on the engine.
rennch 06-25-2020 12:13 PM
Next Blasphemy Build project is to recreate the front end and make it “stock looking” while retaining all this trick air ducting. I’m on the hunt for a hood and some hinges.
https://uploads.tapatalk-cdn.com/202...de932173af.jpg
https://uploads.tapatalk-cdn.com/202...08258709db.jpg
https://uploads.tapatalk-cdn.com/202...e43c61ef3f.jpg
Andy Somogyi 06-25-2020 12:21 PM
What are those front radiators you’re using?
The ducts look good, pretty similar to the design I came up with for my 912, (which is based on the Porsche 996)
Sent from my iPhone using Tapatalk Pro
rennch 06-25-2020 12:22 PM
Those are actually the oil coolers that came with it. I have not sourced radiators yet. Definitely open to suggestions.
Andy Somogyi 06-25-2020 12:50 PM
For my build, 76 912, I’m following the Colin Chapman philosophy of light and simple, so I’m going with a built (cams, STi crank and rods, ITBs) normally aspirated Subaru 2.5, at around 215 hp. This motor is actually lighter than the original VW Type4 that was in there.
Anyways, lighter, smaller motor let’s me run smaller radiators. I worked out the math, and came up with about 200 square inches of radiator frontal area is about the minimum.
So what I’m doing is I’m fitting a pair of Austin Mini radiators (106 square inches per side) under the headlights, and making a complete fiberglass ducts for them. These ducts will have a 12” fan on the back side, and exit into the low pressure area directly under the car. The ducts will basically form an expansion chamber on the front, that increases the static pressure of the incoming air stream. It’s based on the Porsche 996 design.
I spent a lot of time looking up radiator sizes, and the Mini rads fit about the best, all I really have to do is modify the end tanks and re-locate the water lines.
I estimating that this will just about enough, and as a plan-b, there’s more room on the right, so could take a Chevy impala radiator, saw it in half, weld up the end tanks and that will give another 60 square inches.
I’m using a modified 964 bumper (I like the cleaner rounder lines if it), and this forms the front part of the ducts.
I need to put together a video of the design.
https://uploads.tapatalk-cdn.com/202...1c7c283455.jpg
ryans65 06-25-2020 01:08 PM
speaking of blasphemy builds ^
Larmo63 06-25-2020 02:46 PM
I'm sub'd and watching......!
rennch 06-25-2020 09:37 PM
Originally Posted by Andy Somogyi (Post 10921334)
For my build, 76 912, I’m following the Colin Chapman philosophy of light and simple, so I’m going with a built (cams, STi crank and rods, ITBs) normally aspirated Subaru 2.5, at around 215 hp. This motor is actually lighter than the original VW Type4 that was in there...
If I were doing a 912, I would do the exact same thing. The Subaru motor I am putting in is also a flat six, lighter than an SC motor, considerably more stock horsepower at 240, and costs $1200.As a bonus, it was Co-designed by Porsche as evidenced by the German part numbers when you tear it apart.
Are you doing iWire?
Andy Somogyi 06-25-2020 10:46 PM
Yes, it’s amazing how similar the Subaru (EJ, EG and EZ are to the Mezger engine. Certain parts even interchange.
Sounds like you’re going with an EZ — that’s a great engine, with the right ECU just loves to rev. I’ve seen one running with Triumph motorcycle ITBs and sounded amazing.
I’ll be using a Speeduino ECU with my own harness. I’m using an extra daughter board for extra analog outputs to drive all my OEM gauges. It’s pretty simple to write Speeduino modules.
Bigtoe32067 06-26-2020 04:55 AM
Please don’t stop updating this. I think a lot of us are interested but just don’t speak up.
On the other hand, I’m not into YouTube or videos much. I’m old school and prefer pics.
But don’t let that influence you. Most of us will use YouTube in our life when we need instruction on certain things.
I’m curious to see it when it’s finished. Keep up the good work and thanks for bringing it here for us to enjoy.
Good luck
Tony
rennch 06-26-2020 09:33 AM
Good luck
Tony
That's helpful, thank you. It's more difficult to maintain a detailed build thread when video tells the story so well. I wish the Pelican forum had better video integration...as it is, it's a little antequated. I'd love to be able to upload native video files, but it's not set up that way at the moment.
I'll try to do a better job documenting the install by taking pics with my phone as well as shooting video with the Canon.
Trackrash 06-27-2020 08:05 AM
Originally Posted by Cory M (Post 10923520)
I watch my share of car build stuff on YouTube but it's usually not air cooled Porsche. I've watched a lot of import race/track cars, rally, 4x4, even drift car builds. I guess I just find the different projects more stimulating and interesting than what I have done or am doing. I prefer the format of a forum and pictures for discussing and learning stuff in detail. Videos tend to be more of a one way flow of info.
I have to say that I am of two minds when it comes to youtube. I watch quite a bit of videos. Mostly music or entertainment stuff.
On the other hand, I don't enjoy and avoid informational or instructional videos. Not that those don't have value, but I usually hit the fast forward to get the info I'm after. Sorry, I am old school that way. I don't watch TV news either.
For example your posts #67 and 93 are great AFAIK. JMHO.
I do want to follow your build, as I find it interesting.
rennch 06-28-2020 03:20 PM
I started working on attempting to modify the racing front end back to a semi-stock looking form, so I could fit a front bumper and a stock hood with a hood latch:
<iframe width="560" height="315" src="https://www.youtube.com/embed/N2FloQD5JUc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Andy Somogyi 06-29-2020 05:39 PM
Saw your vid on YouTube.
The air intake is nice, keep it. What I suggest is have the center air inlet route air into the front fenders. Mount a pair of radiators in the fenders, similar to Pete WEVO build. The front part of the fenders gets sealed off, connected to the center intake and the rads. This front part forms a perfect expansion chamber. By Bernoulli’s law, the high velocity incoming air enters the expansion chamber, slows down and increases static pressure. It’s this static pressure that actually creates the force to drive the air through the radiators.
https://uploads.tapatalk-cdn.com/202...8c05b4411e.jpghttps://uploads.tapatalk-cdn.com/202...ce9daed518.jpg
rennch 06-29-2020 06:21 PM
The way you have this routed would force a major rerouting of the existing engineering. I'm trying my best not to do that.
Andy Somogyi 06-29-2020 08:45 PM
Not really, you're almost there. You keep the center duct, that's great, and those ducts right now exit into the front part of the fenders, under the headlights. That's really good, because where the ducts dump into the front fenders is pretty close to an ideal ducted radiator design.
Basically, all you have left to do, is get some sheet metal, cut them to the vertical shape of the inside the fenders, cut an exit hole in them, and mount the radiators to them. All you really have to do is get some foam so these sheet metal parts fit snugly under the fender.
You're closer to mounting the rads than I am, because in my case, I need to make molded fiberglass ducts to route air to the rads, and duct the exhaust down, under the wheels. Because you've got the center duct, that's about 3/4 of the work right there.
If you look at Pete's build right here, he's running a pair of custom 16x9 radiators, that's 144" per side, or total of 288 inches or area, and he's proven that area works, even with less than ideal ducting.
http://forums.pelicanparts.com/porsche-911-technical-forum/518231-pvx-build-thread-one-view-slope.html
rennch 07-08-2020 11:17 AM
Paint Stripping!
I don't generally like to do a lot of "time lapse" for my restoration videos, but watching paint remover work at 20x speed is REALLY cool!
<iframe width="560" height="315" src="https://www.youtube.com/embed/rWsYO9gEhLQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 07-09-2020 07:10 AM
Here are some pics of the paint strippage, including some mystery holes in the roof that don’t seem to have a purpose.
https://uploads.tapatalk-cdn.com/202...feb2721e42.jpg
https://uploads.tapatalk-cdn.com/202...d53266ed5b.jpg
https://uploads.tapatalk-cdn.com/202...08037107bf.jpg
https://uploads.tapatalk-cdn.com/202...d3137f8981.jpg
https://uploads.tapatalk-cdn.com/202...fbd93b5b67.jpg
https://uploads.tapatalk-cdn.com/202...5a5a5b530b.jpg
https://uploads.tapatalk-cdn.com/202...12d844501c.jpg
https://uploads.tapatalk-cdn.com/202...5218d0444e.jpg
Cory M 07-09-2020 05:04 PM
Great progress, those holes are probably old repairs from a dent puller.
rennch 07-10-2020 08:56 AM
That’s what I thought as well… But there is zero evidence of any dent. Besides… You can access it from the underside. No need for a dent puller.
rennch 07-11-2020 05:47 PM
I used an 80 grit DA and this LPS3 product recommended by John Benton to get a smooth, waxy protective finish.
https://uploads.tapatalk-cdn.com/202...dae24246dd.jpg
https://uploads.tapatalk-cdn.com/202...f444f1a12f.jpg
https://uploads.tapatalk-cdn.com/202...a97ae34e83.jpg
rennch 07-11-2020 06:27 PM
https://uploads.tapatalk-cdn.com/202...ac871c6b40.jpg
Flojo 07-12-2020 07:28 AM
nice garage space.
rennch 07-16-2020 10:25 PM
Originally Posted by Flojo (Post 10942872)
nice garage space.
It's getting there! Still have to do the floors on the other side, and I have a couple more surprises, but it's coming along well!
rennch 07-16-2020 10:28 PM
Engine has arrived!
http://forums.pelicanparts.com/uploa...1594967181.JPG
The engine HAS arrived! Here's a link to the video...I'll eventually post some pics in a couple days.
<iframe width="560" height="315" src="https://www.youtube.com/embed/vR1iUi5cWeE" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Hi_Fi_Guy 07-17-2020 07:56 AM
Another response to say I enjoy your post here as well as your youtube videos. Keep it up. Can't wait to see your final results and learn about the performance of the finished car and if you still feel it stirs the soul when driving. The price of that engine was certainly right!
rennch 07-17-2020 01:36 PM
Thanks dude. Do we have hifi audio in common too? Do you know about my Beginner Audiophile Podcast?
rennch 07-18-2020 06:19 PM
My adapter plate hasn’t arrived yet, so I fabbed up some 1” square tube “standoffs” which are the same width as the adapter plate.
https://uploads.tapatalk-cdn.com/202...7bd633da23.jpg
https://uploads.tapatalk-cdn.com/202...7c707c498e.jpg
Here is a Subaru EZ30 flat 6 “mated” to a 996 (g96) transmission.
https://uploads.tapatalk-cdn.com/202...8dfc1626cc.jpg
https://uploads.tapatalk-cdn.com/202...18025e78bc.jpg
I rolled it under just to see where everything lines up, and have a think about engine and transmission mounts. TONS of room for activities (read: twin turbos) in the back!
https://uploads.tapatalk-cdn.com/202...960b7a2273.jpg
https://uploads.tapatalk-cdn.com/202...256fd29ef5.jpg
https://uploads.tapatalk-cdn.com/202...43fe8485a9.jpg
https://uploads.tapatalk-cdn.com/202...e7384c7685.jpg
Good progress for the day!
rennch 07-20-2020 10:38 AM
In case anyone wants to know what this engine sounds like when pi$$ed off: <iframe width="560" height="315" src="https://www.youtube.com/embed/uod6avfs4AM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 07-22-2020 09:47 AM
And here's the video for said adapter plate:
<iframe width="560" height="315" src="https://www.youtube.com/embed/IZ2cSg4zSOY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
