3.2 misfiring after engine drop
Four weeks ago I installed my rebuilt engine and transmission, and the engine ran well.
Pulled hard, ran right up to the rev limiter, etc.
Two weeks ago I dropped the engine and gearbox to attend to an issue in the gearbox.
Didn't do anything to the engine other than change the oil.
Now, it starts fine, and pulls well up to about 6000 RPM then starts misfiring, and won't go past that speed.
I thought about the flywheel speed sensor, so checked the gap and it was fine.
Also checked over all the wiring for a loose connection.
The symptoms:
  • in neutral, the misfiring happens at about 4500 RPM - engine won't go past that speed unless its given full throttle from a lower speed, in which case it will go up to about 5000
  • in 2nd gear, accelerating gently, the misfire happens at about 5500, but if I accelerate hard it will go to approx 6200
  • In 3rd gear,accelerating gently, it misfires at about 5500, but accelerating hard it runs up to the rev limiter.
  • Up to the point of misfire, it runs as it did before
When it misfires, it feels a bit like the rev limiter, so it leads me to think electrical rather than fuel.
BTW, it has an Autothority MAF and a SW chip; both have been in place for years.
I can't think of what I might have disturbed during the drop that would cause such an effect.
I have run out of ideas, and sure would appreciate some help.
Bob D.
'84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 22/27 TB, 22/21 SB, bunch of other little stuff
'69 Lotus 7 Series 3; '74 Fiat X1/9
'14 X5 diesel
Old 08-15-2019, 12:19 PM
I'd check and clean the Hotwire in the MAF if you haven't done so recently using MAF Hotwire cleaner. When dirty, the Hotwire can't accurately sense airflow and can provide the DME/SW chip with invalid readings. Not sure why this would not have manifest itself before engine drop, but is similar to a situation I had with my (non-autothority)MAF some years ago
Old 08-15-2019, 12:38 PM
shh-the robot is sleeping
I have had similar experiences. The culprit a few times is the way the distributer cap sits. Sometimes it can rock a few degrees off center causing the symptoms you’ve described. I would check it and see if maybe you knocked it while moving the engine.
'88 911 Coupe, 69k miles
Old 08-15-2019, 02:53 PM
I'll double check the MAF, and the distributor.
I did notice when poking around that I got a shock from one of the plug wires at the distributor cap.
Bob D.
'14 X5 diesel
Old 08-15-2019, 03:45 PM
Checked the distributor, it looked fine but I reseated it anyway.
MAF looked clean but I gave it a thorough cleaning.
Neither helped; it still misfires
4500 with no load, 6000 or so with a load.
It feels much like hitting the rev limiter.
Bob D.
'14 X5 diesel
Old 08-16-2019, 10:26 AM
longshot, but broken idle position microswitch (or loss of continuity in circuit between microswitch and DME after second engine drop) would cause fuel starvation/cut-off at higher rpm (if it always reported closed throttle/idle status to DME) -- see Idle position switch question
Old 08-16-2019, 10:49 AM
You would have removed the coil to distributor lead to drop the engine, so I would check the continuity of the wire with a multimeter and make sure it is seated properly on both ends. I would also check every electrical connection that you had to unplug and plug when you dropped the engine. When I did a major service on my 3.2 a while back, I didn't get one injector plug and the plug to the CHT sensor properly seated, so shortly after the service the car started running like crap. I just checked every connector that I had touched and I found the problems.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 08-16-2019, 10:50 AM
It was the CHT connector. It was almost seated, enough that I didn't notice.
Also I didn't think of the CHT because it didn't seem to me it would cause such a problem.
And, of course, I went looking for zebras instead of horses :-)
Thanks to all for the great advice.
Bob
Bob D.
'14 X5 diesel
Old 08-16-2019, 11:14 AM
great news - thx for posting the solution!
Old 08-16-2019, 01:25 PM
I thought the problem was solved, but ....
The CHT connection got rid of the lower speed stuttering.
However, at higher speeds the feeling that it is hitting the rev limiter is still there;
-in neutral, or in 1st gear, whether increasing revs slowly or quickly, occurs at about 6100
-in second, occurs at 62-6300
-in third, at about 6500
-in 4th, was OK at 6600 then I ran out of road.
I have replaced the DME relay and the fuel filter, and cleaned the MAF and all the connectors on the engine.
Also verified the idle and full throttle switches.
The 14 pin connector is cracked, and Ihave a new one coming, but it isn't clear how that connector would cause such a problem.
The car runs great up to the stuttering; at a track event I just shifted a bit early.
With the mild state of tune of my engine, I don't need the higher rev limit but not being able to find the problem is frustrating.
Is there any chance that the flywheel speed sensor would cause this if it was on the edge of the adjustment?
An ideas will be appreciated.
Bob D.
'14 X5 diesel
Old 09-05-2019, 01:17 PM
Just curious... what did you do to your transmission that you needed to drop the engine?
I'd look at that areas first.
1987 Porsche 911 Carrera Coupe
Old 09-06-2019, 06:41 AM
That's fond- just deglaze
Hi Bob- FWIW (and also after engine drop) my misfires occurred at around 4500 rpm. Adjusting both the Speed & Ref Sensor clearances solved my problem!
Missed Approach
Petra- 1986 Coupe
Old 09-06-2019, 06:49 AM
Dropped the engine/gearbox to replace a bad bearing on the input shaft.
I adjusted the speed sensor but it is hard to do with the engine in, maybe I'll redo those.
Any tips for doing them without dropping the engine?
Bob D.
'14 X5 diesel
Old 09-06-2019, 09:21 AM
I had a similar experience with a 3.2 a while ago.. turned out to be one of the connectors from the sensors, was not 100% plugged in at that bracket on the lhs of the engine bay.. it 'looked' plugged in, but when I went around pushing on everything, it clicked, and I got lucky.
Old 09-06-2019, 09:47 AM
Hi Bob- I still think this is one of the best references on how to replace/adjust the sensors without an engine drop:
no-spark problem finally resolved
Missed Approach
Petra- 1986 Coupe
Old 09-06-2019, 10:00 AM
carreradpt's Avatar
Aren't these rpms just about at redline?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 09-06-2019, 10:23 AM
The chip provides a 6800 rev limit, not that I need that high with my engine.
The issue I am chasing is that something has changed.
Next step is to reset the flywheel sensors, maybe one or the other is providing a weak signal at high rpm
Bob D.
'14 X5 diesel
Old 09-06-2019, 02:28 PM
The early rev limit problem persists.
The sensors have been re-checked, and I swapped in a new one just to see if it made a difference - no change.
It acts and feels exactly like hitting the rev limiter.
Data from a newly installed A/F ratio gauge shows that the mixture is fine up to the point the "stuttering" starts, then it goes lean. I believe the rev limiter cuts fuel so going lean makes sense.
But it happens at 5900 in neutral and first, 6200 or so in 2nd, and 65-6600 in 3rd.
I found a bad wire in the chassis side of the connector for the speed sensor - the signal wires had adjacent cracks in the insulation, and if the cable was moved into certain positions, the shielding wires would short the signal. Took a while to find that, but once fixed, it didn't solve the problem.
I have contacted S Wong asking if the ECU could be doing this, given that it seems like it is hitting the rev limiter, just at different engine speeds.
Since the A/F ratio is OK up to the point this occurs, I don't think there is any danger to the engine, and will attend a couple of DE's, but this is starting to be a bit annoying. Getting good at changing and setting sensors, though.
Bob D.
'14 X5 diesel
Old 09-13-2019, 05:56 PM
Steve W's Avatar
Since you rebuilt your engine a few weeks ago, my bet is that you clocked the distributor into the case one tooth off. Take the distributor cap off, turn the crank pulley by hand watching the TDC mark as it approaches the mark on the case, and also watch where the rotor points to in relation to the TDC mark on the distributor housing. When the crank pulley comes to TDC, so should the rotor, or within 2 to 3 degrees. If it's off like 10 degrees or more that is your problem.
-Steve
Old 09-14-2019, 12:29 AM
Originally Posted by Steve W View Post
my bet is that you clocked the distributor into the case one tooth off-Steve
I'll check that.
How would that cause the problem , though, especially what seems like a fuel cutoff?
Bob D.
'14 X5 diesel
Old 09-14-2019, 05:41 AM
