brucebark's Avatar
Bizarre turn signal behavior
I have a 1986 911 Carrera.
I just noticed that none of the turn signals are working. Dash turn indicators don't light either. Also, the emergency flashers do nothing.
When the car is off and I move the signal stalk to either left or right, all four turn signals light. L/R and F/R. Isn't the "normal" behavior is for just one side to light when the stalk is to that side?
With the ignition on, none of the signals light up.
Fuses and bulbs are good.
Any ideas where to start??
-Bruce
Old 08-18-2019, 06:55 PM
ROW '78 911 Targa
timmy2's Avatar
Flasher Relay failed? Can you hear it flashing/clicking with ignition in run and signals activated?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-18-2019, 07:08 PM
brucebark's Avatar
No clicking can be heard. Would a bad flasher relay cause light on both sides to light when the turn signal lever is on with everything off?
Where is the flasher relay located?
-Bruce
Old 08-20-2019, 11:51 AM
ROW '78 911 Targa
timmy2's Avatar
Not positive for your year, but most are under the cowl in the trunk on drivers side at the dash.
Some owners manuals have photos of the location. The Bentley does as well.
Behavior: stuck or non op contacts can give multiple symptoms.
Dennis
Old 08-20-2019, 12:01 PM
If this suddenly started and you hadn't messed with any lighting connections, try a new relay and if that doesn't do it maybe your signal stalk died. They do that.
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 08-22-2019, 01:15 PM
Heck, I’m only 5 not 71!
targa80's Avatar
The good news is your failure does point to the flasher relay since both the turn signals and emergency flashers are none functioning. It can also be the power source to the relay and the two circuits.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 08-23-2019, 05:23 AM
ROW '78 911 Targa
timmy2's Avatar
Did you kick or otherwise move one of the 6 pin male plugs under the dash?
Could be as simple as pushing them back into place.
Dennis
Old 08-23-2019, 09:07 AM
German cars are notorious for bad grounds out in the fixtures. The aluminum bits corrode, resistance increases, and some truly bizarre behavior can result. I'd start by insuring that all the grounds are solid.
regards,
Phil
Old 08-23-2019, 09:22 AM
