I am always supportive of good causes. I will PM you later with details about how to get a 911 Kit to the winner of your auction. Also, it is great to have someone so knowledgeable about these engines weighing in. I thought your article on valve adjustments was excellent. That is why I linked directly to your site in order to give you full attribution. I am in Redondo Beach much of the year and would like to visit your shop sometime.
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
2 day delivery !!!
Thanks Brad. Ready to wrench !!!
1979 SC 1986 Carrera 3.6 L+ |
Reiver
Every time I see a red fan I think...MotorMeister….I am sure I am wrong here but can't help it....they were very quick on shipping mine too...very nice kit.
De Oppresso Liber Strength and Honor 5th Legion |
No MM here, solid lifters,ss cams,hd valve springs,Anchor atl head rebuild,Tune/dyno @ 2nd Street Speed.
And soon to be,Snap Gap - perfectly set valve train.
Runnin on empty
Got my kit last week. Brad shipped it really fast. Now I have the horrible job to put a few thousand miles on my fresh motor
![]() The kit quality seems excellent.
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
Mighty Meatlocker Turbo
For anyone in So. Cal. who is attending Cars and Coffee with our host this Saturday and has questions about SNAPGAP or wants to talk valve adjustment, I will be there. Driving a black 2015 Cayman S and wearing a blue SNAPGAP hat. Hope to see you.
82 911 SC - Ancora Imparo
Not that it affects the performance, but your packaging is spot on. Much nicer than the ziploc bag that the Kirk tool arrived in.
Ethan 1982 911 SC - Wine Red Metallic Coupe |
I’m convinced. I finished the install of the SnapGap kit and I am very impressed with it.
I’ve owned my 911 for 15 years now and drive about 1000 miles a year. This is the fourth time I have adjusted the valves. Every other time was with the standard little feeler gauge tool and I always hated it, fighting to get the feeler gauge blade under the foot of the adjuster then not knowing for sure how tight was “just right” because I did it once every 3-4 years. I always second guessed my adjustments and was always sure I got at least one or two wrong. This kit solves that problem and now I have confidence tackling this procedure. Brad is very responsive will answer any questions you have, the product is well designed and well packaged. The instructions are concise and unless you want to futz around and take your time to “bond” with your car like I do when I work on it once you do two the process is really just as quick as a normal adjustment. Plus Brad is a Pelicanite! |
Great testimonial. I’m giving this too more than serious thought.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Well... I have been out of it for awhile... I was about to do a valve adjustment when I came across this... I'm in!
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Looks very interesting. I am comfortable adjusting my valves with a feeler gauge. I tried the Kirk tool and it just didn't make things easier for me. Back to the old way. This looks very well designed and seems to simplify the process. My question is about the "next" valve adjust. What is the process for that?
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
I have done maybe 4 or 5 adjustments to 2 different cars but I end of going back and double check them. It's time consuming and I feel like a do a good job.. but there is no way my feel is going to be as accurate as this shim. I'm excited to give this a try.. and throw them in both my P cars and my bug if they work out.
This is a great idea for when the engine is out of the car. But numbers 6 is hard enough adjusting the regular way. I just cannot see back there. Then like someone said, The valves by the cat are a problem. At least for me.
Man I hear you but this video is what made me want this tool.. it is the #6. https://www.facebook.com/watch/?v=2269038523200232&extid=BE7QKF30oUgNGAmw
Back to the shim falling out. So I come back some time later to readjust the valves. Could? as I loosen the nut the shim fall out and fall into some part of the exposed engine??
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
In the videos on the site you can see it is barbed so it can't fall off, theoretically.
Thanks for that Brad. Cool product.
just ordered the Snapgap kit this morning..can't wait to try it out..
