-   -   It started off as a simple valve adjustment... (http://forums.pelicanparts.com/porsche-911-technical-forum/1038108-started-off-simple-valve-adjustment.html)
mtl911sc 08-23-2019 11:49 AM
Originally Posted by 76FJ55 (Post 10568293)
What lift do you have? I'm considering getting a 4 post and the engine obviously fits between the rails of your.
Well yes & no. My lift is a Dannmar D-7 and I did what others have done on this forum. Decided to move the free rail i.e. the one without the hydraulic cylinder out as far as possible, which gave me the necessary extra few inches of clearance between the ramps. The ramp simply rests on the frame underneath so not much to move it.
Didn't have the stomach to hang the car's ass over the back of the lift, which seems to be another popular alternative when doing a drop on a 4-post.
mtl911sc 08-23-2019 12:02 PM
Originally Posted by pmax (Post 10568419)
The lift lowers enough for the jack ?
Actually the issue was getting the jack high enough to support the engine/trans before pulling their respective mounting bolts. My jack maxes out at 22" which wasn't high enough to still be able to get under the lift to remove the transmission bolts. The extra height gained with the pallet etc made it a lot easier. Then it was just a matter of carefully raising the lift/car off of the engine.
Of course, now I can't move the engine anywhere but plenty of space to work underneath the car since it's not going anywhere either.
wildcat077 08-23-2019 12:43 PM
Did you lift the car off the engine ?
I made a sling and picked up the rear of the car with an engine hoist using the two holes for the engine mounts in which i inserted two large eyebolts.
Had to make two stands out of wood blocks to get get the front wheels off the ground about 12 inches and i was able to slide the engine out from under the car without removing the rear bumper ...
Ahhhhhh ...memories !!!
mtl911sc 08-23-2019 08:04 PM
Yup, car lifted and engine stayed put.
