-   -   It started off as a simple valve adjustment... (http://forums.pelicanparts.com/porsche-911-technical-forum/1038108-started-off-simple-valve-adjustment.html)
mtl911sc 08-22-2019 06:37 PM
...and quickly evolved into this :D
http://forums.pelicanparts.com/uploa...1566523905.jpg
http://forums.pelicanparts.com/uploa...1566523905.JPG
What an awesome and beautiful lump
Reiver 08-22-2019 07:17 PM
Because??
mtl911sc 08-22-2019 07:19 PM
Decided to finally fix the leaks that made such a mess of the engine, and which also made the valve adjustment job pretty unpleasant - everything was coated in a dirty oil residue.
dannobee 08-22-2019 07:23 PM
At one of my first jobs, the old guy who owned the place could whip out a 911 engine in less than a half an hour. I swear he'd pull it out for anything more than an oil change (slightly exaggerating, but not by much). After awhile, I felt the same way, too. Valve adjustment AND an oil leak from something on top? It's coming out!
3rd_gear_Ted 08-22-2019 07:27 PM
It started as a valve adjust......
And then a head stud fell out:eek:
Fixed it with a 3.6L:D
pmax 08-22-2019 08:22 PM
Gotta love that jack stand , tripod (?) and the rotted pallet.
Canada Kev 08-22-2019 08:55 PM
So... did you get your valves adjusted...? ;)
Flojo 08-23-2019 03:07 AM
Originally Posted by pmax (Post 10567790)
...and the rotted pallet.
yep. at first glance one wonders how it can support these 200+ kg of weight, uh...
911tracker85 08-23-2019 06:23 AM
Rotted pallet? nah that is just nicely weathered....
but do wonder why you used it?
I am also moving toward the 'pull the engine' for anything more involved than oil change. same with my 944s for anything involving getting to the bell housing.
good luck.
'78 SC 08-23-2019 06:47 AM
Same here. In 2003, pulled the lower valve covers for a routine valve adjustment and it started raining headstuds. :eek: Engine drop #1.
Seven engine drops later, I have the tools and checklists to take the stress out of the process. Still takes almost two hours to get it out and on the stand, but can do it alone and know I'm not damaging anything.
garment 08-23-2019 06:50 AM
Think you could share the list of tools and checklists? I’m always on the lookout for those who have created such guides - I’ve not pulled an engine yet, but my oil consumption figures indicate I’ll have to do so...
2jmotorsports 08-23-2019 09:10 AM
You have been blessed. That engine chose you as its rebuilder.
Praise be to the Porsche Flat 6.
76FJ55 08-23-2019 09:17 AM
What lift do you have? I'm considering getting a 4 post and the engine obviously fits between the rails of your.
wildcat077 08-23-2019 10:35 AM
Well ... that's one way of doing a valve adjustment ... lol
After the last one i did , i decided to install a 95 3.6, no more valve adjustments ... wooooohooo !
pmax 08-23-2019 10:54 AM
The lift lowers enough for the jack ?
Trackrash 08-23-2019 11:31 AM
Any broken studs?
Someone has to ask....
mtl911sc 08-23-2019 11:31 AM
Just tallying up the $$ for everything I want to do while it's out, which could take a while lol. Oh, and waiting to receive my valve adjustment tool.
mtl911sc 08-23-2019 11:33 AM
Good eye pmax, that's indeed an inverted jackstand to back up the jack.
Rotted pallet was outside for over 9 years, it was what my 4-post lift was delivered on so it's appropriate ;)
mtl911sc 08-23-2019 11:34 AM
Originally Posted by Trackrash (Post 10568461)
Any broken studs?
No broken studs, the stud gods are smiling on me (for now anyway).
mtl911sc 08-23-2019 11:41 AM
Just needed the extra height for the jack not to be maxed out before lifting the car, and didn't have the necessary wood (2x4, 4x4 etc) lying around.
