sump plate torque and sealant questions
Anyone know the proper tightening torque for the 6mm nuts that mount the oil sump plate to the bottom of the engine?
- Also do you use any sealant on the gasket or plate or just install it dry? Thanx L
Old 08-24-2019, 09:30 AM
Senior Member
Superman's Avatar
No sealant. Proper torque is less than one might think. Virtually just a little tighter than finger tight. If it leaks, it's because someone overtightened it and deformed the flatness of the plate.
Mocha 1978 911SC. "Coco"
Old 08-24-2019, 09:58 AM
Under the radar
Trackrash's Avatar
The spec is 7 lb/ft. I use Curl-t sparingly and have no leaks.
Just use a 1/4" socket wrench and cinch them up gently.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-24-2019, 10:37 AM
proporsche's Avatar
one more thing..make sure you use 2 gaskets...and the best is graphite type..use nylon nuts with alu washers not any other nuts with springs washers....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-24-2019, 01:04 PM
