sump plate torque and sealant questions
Anyone know the proper tightening torque for the 6mm nuts that mount the oil sump plate to the bottom of the engine?
- Also do you use any sealant on the gasket or plate or just install it dry? Thanx L |
Senior Member
No sealant. Proper torque is less than one might think. Virtually just a little tighter than finger tight. If it leaks, it's because someone overtightened it and deformed the flatness of the plate.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Under the radar
The spec is 7 lb/ft. I use Curl-t sparingly and have no leaks.
Just use a 1/4" socket wrench and cinch them up gently.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-24-2019 at 10:40 AM.. |
one more thing..make sure you use 2 gaskets...and the best is graphite type..use nylon nuts with alu washers not any other nuts with springs washers....
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
