Oil Leak Pattern Identification
Hi Pelicans,
Im chasing oil leaks on a 73.5 911T.
Lots of smoke from left heat exchanger.
Pulled the exhaust manifold to replace the return tube seals and found the pictured oil pattern.
Is it possible to tell from this pic if the rocker shaft seals are leaking and or if it is only the return tubes?
Thank you
Maze
Old 09-04-2019, 05:57 PM
that looks to be more than just return tubes, but you cannot be sure until you remove the valve cover. Then you can see it for sure.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-04-2019, 06:03 PM
If the rocker shafts look dry on their ends, that's sealant failure between heads and cam towers. Very common. Leaking exhaust gaskets as well.
206 637 4071
Old 09-04-2019, 06:39 PM
Senior Member
Superman's Avatar
Insides of the cam towers look nice and bright. You use good oil. At least...oil with low paraffin content.
Mocha 1978 911SC. "Coco"
Old 09-04-2019, 07:15 PM
Under the radar
Trackrash's Avatar
You might want to check your head stud tightness as well.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-04-2019, 07:48 PM
Flojo's Avatar
this.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-05-2019, 01:32 AM
