slater's Avatar
what fog lights do you use?
I need to fill the big holes in my bumper with some new fog/driving lights. But to be honest, I am not a big fan of the stock ones I have now. Has anyone else out there put anything different in there? If so, I would like to see pictures or hear anything you have to say. -KS
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 03-26-2003, 04:59 PM
Re: what fog lights do you use?
I would like to see pictures, and I'll have plenty to say..
also, is this for city driving? do you get a lot of fog up that inlet?.. do you have to have fogs? I get some fog, but not like the west coast...... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-26-2003, 09:26 PM
slater's Avatar
It can get foggy, but not all that often. Usually only in the november and december months. I dont need them, but i would like to have something there
Old 03-26-2003, 10:32 PM
Cool
OK.. this is what I would do. turn your fogs into strong low beam lights.. use real bulbs, like Narva 130w.. have the fog/low beam relay triggered by the high beam wire..
the high beam throws a different light pattern than the lows.. if you use 130w on your high beam w/real bulbs the combo will be fantastic.. real high beams require re-wiring and relay/relays.. which is an uncomplicated/clean install.. and inexpensive.. your lens selection for the added low/old fogs is important.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-27-2003, 05:09 AM
