| Registered |
				Measurements Targa/Cab Release Handle
			Hello all, I have a 1985 Carrera convertible that is missing the targa/cab top release handle/release key for the roof lock. Pricing is outrageous and fabricating these should be fairly easy. I could try to design it on the fly but it would be great if a fellow Pelican could post measurements of a key that they have in hand, i.e. round stock size, cross pin size, cross pin position, etc. Thanks in advance! Richard   | ||
|  09-13-2019, 07:10 AM |
| Registered Join Date: Aug 2018 Location: San Diego, CA
			I'll draw one up for you. Matt
				__________________ 1978 SC Targa | ||
|  09-13-2019, 07:47 AM |
			Not sure how much of the detail is critical.  The pin is tapered, probably for ease of assy.  There is a notch at the top, I think this is what captures the key if you press it in all the way.  And another step to 4mm further down the shaft.
|  09-13-2019, 08:23 AM |
| Registered |
			Matt, VERY nice! Thanks for the quick reply - hope this helps others also. Richard | ||
|  09-13-2019, 10:00 AM |
| Registered Join Date: Apr 2002 Location: Omaha, NE
			I thought I saw Rennline was making these.  Might want to check.
				__________________ 1980 911SC Targa 3.6L | ||
|  09-13-2019, 11:18 AM |
| Registered |
			They're $61 new for a reproduction. I guess that's not cheap, but I wouldn't call it outrageous either. Certainly more cost effective to buy one than fabricate.
|  09-13-2019, 06:03 PM |
