1973.5 911T
1973 Carpet Install Sequence
Hello,
I am looking for guidance on the install sequence of the carpet pieces for my 1973 911T.
Is the layout in the photo correct?
Can anyone with experience possibly assign a number to the pieces with the correct install sequence?
Thanks for any help!
Old 09-12-2019, 10:26 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Dont think it matters much as long as the nice edges are on the outside and rough edges are tucked under. I put down some sound insulation first. Makes it a bit nicer.
Chris
73 E
Old 09-12-2019, 02:11 PM
AutoBahned
RWebb's Avatar
I'm wanting to do that on my '73 too. There are tons of posts & tips but I'm not clear on how many really relate to the LWB cars...
There was also a guy who used a 'green' adhesive and saved his liver...
2 things I think I recall...
1. work from back to front
2. the door pockets are tricky
Old 09-12-2019, 03:38 PM
I bit late, but this was a sequence I found somewhere. It helped and it does matter which you do 1st if you don't want to end up redoing it a couple times.
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago
89 944S2 Daily Driver-Sold because...still thinking why.
73.5CIS Targa Shed Find -On the Road Again
Old 02-07-2021, 08:11 AM
Where did you source your interior?
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 02-07-2021, 08:21 AM
This is late to the game too, but for anybody with the carpet sequence question later on, this might help.
Marv Evans
'69 911E
Old 02-07-2021, 09:33 AM
PCA Member since 1988
I did this job last year. Real PITA. The sequence in the drawing above is correct, although you can deviate a little where the pieces don’t overlap. Also, the front panels with the map pockets may be in pretty good shape. I left mine alone, and figure I can replace them later if I get motivated. There’s only about an inch of overlap between that piece and the piece along the side longitudinal.
You will need to use a heat gun liberally to mold the pieces around the bends and curves. This is the part that’s a PITA. And you’ll get blisters in your fingers from pulling and stretching the carpet as you heat and fit it.
Old 02-12-2021, 01:05 AM
7783911's Avatar
I did custom carpet last year and used snaps where I could instead of glue. so much easier to access the tunnel etc as a result
Old 02-12-2021, 05:04 AM
