hfb hfb is offline
Question 73 1/2 911 CIS warm up regulator
I am replacing the warm up regulator and have a problem!!
The original has a SINGLE spade connector and the replacement has a DOUBLE connector. I thought the new one needed to be grounded but when I ran a continuity test, only the terminals had conintuity. How do I wire this warm up regulator? Could sure use some help if you have been there, done that Thanks hfb
Old 03-27-2003, 11:36 AM
