Drive it like u stole it.
jonesb930's Avatar
Front Condenser Block-off
Looking for suggestions and pictures of how others blocked off the opening for the front blower/condenser. I know Rennline makes a block off that mounts to the blower motor mount. I’m looking for something that eliminates everything.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-01-2020, 08:46 PM
Take the plastic blower motor housing, trace it out on a sheet of aluminum, complete with punch pips for the screws. Cut & drill it out. Clean out all the smutz. Remove the condenser thing, but leave the bar guard in front of the condenser thingy. Mount your new plate with a thin layer of dum dum to seal it.
If you don't know dum dum, think flex-seal from a tube. It makes screen doors float. In fact, make the plate from an old screen door & then just spray it with that stuff. In fact just spray the condenser with enough flex seal, & viola, water tight.
Old 01-01-2020, 09:52 PM
Dum dum is simply ribbon calk.
Old 01-02-2020, 05:59 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Condenser shield.
Look on used parts for a condenser shield.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-02-2020, 06:52 AM
jonesb930's Avatar
I did look into using the blower motor mount and just putting a small flat piece of aluminum over that opening. I really would like to eliminate the entire assembly though. The picture does not show it but it is not flat. It has a radius step up along the side toward the front of the car. Rennline sells the small block-off for $20 but like I said, I was really hoping to eliminate the entire assembly. #14 in the picture is what I am trying to eliminate.
#14 911 501 581 01 Air baffle plate
Bill Jones
Jupiter, FL
Old 01-02-2020, 02:24 PM
