Lash
What does this plug connect to?
Getting ready to reinstall the engine in my 1980 SC. Making a check list for all electrical and fuel line connections that need to hooked up as I reinstall the engine. I cannot figure out where this two prong connector goes. It is on the left side of engine, one brown wire and the other is red/white. It looks like it goes to the other side of engine to the supplementary air valve. Looking in the Bentley Manual page 970-8 lower right corner it shows the valve with the same colored wires.
So where on the left side of engine bay does it connect to???
I was going to make a continuity check at the valve but was not able to disconnect the plastic plug from the valve, did not want to break the plug.
Old 09-22-2019, 07:31 PM
ROW '78 911 Targa
timmy2's Avatar
Not used after ‘79 on US models. Just tape it up and tuck it out of the way.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-22-2019, 07:37 PM
Lash
timmy2
Thanks, after looking at the cable closely I could see where it had been folded and wire tied. Must be the mechanic that did a top end job cut the tie.
Lash
Old 09-23-2019, 07:35 PM
ROW '78 911 Targa
timmy2's Avatar
Factory just covered the terminals with tape 0n the flats, then a wrap around to secure the tape, then tucked them out of the way.
Dennis
Old 09-23-2019, 08:04 PM
911tracker85's Avatar
as I was helping a friend resurrect his 84 944, commented that he will occasionally find connectors not plugged into anything. they may be for things / features your car does not have. as long as all the major things work.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 09-25-2019, 06:51 AM
Wire plug
Could be plug for remote voltage regulator which was used on early CIS cars. Later Cis cars voltage reg. were integrated.
Dan Petchel
CarsincNJ.com
Targa top Restoration
Vintage parts
609 298 2277
carsinc@comcast.net
Old 09-25-2019, 08:36 AM
ROW '78 911 Targa
timmy2's Avatar
Dan, it is used on 78/79 SC’s (and ROW cars after) for the vacuum time delay switch.
80-83 Lambda cars didn’t use it, but Porsche only built one engine harness for all SC’s with Lambda or without Lambda.
Dennis
Old 09-25-2019, 08:44 AM
Looks like the Blower motor plug
Old 09-25-2019, 08:52 AM
ROW '78 911 Targa
timmy2's Avatar
It’s not....
Dennis
Old 09-25-2019, 09:00 AM
theiceman's Avatar
goes here on early CIS cars ( mine is 78 )
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-25-2019, 09:16 AM
