Question Install ZF 964 turbo LSD to 911 3.2 G50
Hi, my name is Shinji, Japanese 1987 911 owner.
I got ZF 964 turbo LSD (genine) and tried it to install my 911 3.2 NA with G50.
After the LSD installation, when I rotated a joint flange, I could not rotated it (It was completely fixed)
When I loosened transmission cover bolts a little, the flange was rotated well.
I again removed the LSD and checkd sims and bearings but these were no problem.
I thought ZF 964 LSD fits 911 with G50 mission.
Do I need to replace sims and adjust backlash?
Could you give me some advises?
I hope I had some mistake...
Thanks,
Shinji, Y
Old 09-29-2019, 04:08 AM
gearhead
You absolutely need to reset the backlash. The ring gear flanges aren’t the same thickness. This is why there are two different length ring gear bolts.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-29-2019, 10:07 AM
Hi Matt san,
Thanks for your advise. I will try to reset the backlash this weekend.
Thanks,
Shinji, Y
Old 09-30-2019, 06:14 AM
Tags
3.2 , 911 , g50 , lsd
