What are your favorite Carrera 3.2 upgrades/accessories?
Hi everyone! 👋
Just joined the aircooled family with this Targa from 1987 in Guards Red 😍 What are your favorite Carrera 3.2 upgrades/accessories? On my radar: - Momo steering wheel - Porsche Classic Radio - Steve Wong chip - Fabspeed exhaust - H4 Headlight Conversion - Black Stone guards
3.2 to 3.5
3.2 to 3.5
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Beautiful!!
1958 356A - Sold to a rust collector 1978 924 - sold to a sewing machine repairman 1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB 1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car |
Lighter flywheel, exhaust, +/- ITB’s
Funny you ask as I've been thinking about this recently!
Sorry, I'm going to be really boring and sensible. If I was to buy a third one for street use I would: Immediately Install a fuse in the harness to the front condenser blower. Install one or two fuses in the harness to the ventilation control dash light and the ashtray light If the tyres are older than 6 years or hard compound, throw them away and install a set of Potenza RE003's Restore the suspension so the shocks, bushes and ball joints are all good. Install Turbo tie rods 21mm spacers on rear wheels VDO head unit Carefully set up the gearshift if equipped with a 915. Stage 1 Griffith style AC upgrade Install a switch in console so you can use the AC ventilation fan without the AC compressor operating. M&K 1 in/1 out exhaust Cat delete pipe with o2 bung Wong chip Modern 4 hole Bosch injectors Install J West relays on the headlight circuits Stage 2 VEMS Plug & Play ECU that plugs into standard body harness. AFM delete pipe from Benchmark Solutions to run a MAP sensor but standard airbox Distributor delete by using direct fire Nippon Denso CoPs through an auxiliary harness TPS to replace the standard switch Modern 02 sensor Find a good tuner I've gone Stage 3 on my second 3.2 - 3.4/twin plug/Motec/twin knock sensors/full sequential/direct fire Cop's/BBE headers/993SS cams - but in hindsight, Stage 2 would have been a more sensible place to stop....or to have bought a 996GT3 instead! Last edited by Peter M; 04-16-2019 at 02:30 PM.. |
Did everything on Immediately and stage 1, except I will get round to installing the extra fuses this weekend and one key question : which drop-in replacement injector that is available are you using (SW Chip, std Motronic) ?
I have found a set of Bosch 0280 155 931's to work well in practice and to be quite affordable. I have also verified the AFR's to be very safe on a dyno at all throttle openings and loadings with my Wong chipped '88 so have no qualms in recommending to others. Sal (forum name: scarceller), who I respect highly, noted in a recent post that they aren't an ideal substitute due to different characteristics of low and high impedance injectors but the proof of the pudding demonstrates they work in practice. There is certainly no harm possible to the Motronic. This actually opens up another possibility for my Stage 1 suggestion that should be seriously considered. Instead of a set of 0280 155 931's and a Wong chip, you could send your Motronic off to Sal to be checked over and remapping specially for modern high impedance injectors. But I guess this then begs the question that you may as well spend a bit more and get his MAP sensor upgrade and get rid of the AFM while you're at it. Or spend a bit more again and get a modern easily tuneable ECU that just about any dyno tuner anywhere in the world can handle. It's a slippery slope! Last edited by Peter M; 04-16-2019 at 04:44 AM.. |
(man/dude)
SW chip.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
For me, without a doubt, upgrading the AC.
I live in Oklahoma and drive my 911 through lots of hot weather. I plan to drive to Key West this July. That is gonna be hot. I added two condensers to the rear fender, so I have a 4 condenser AC system. I get to have lots of 40 degree air blowing on my face in 100+ degree days. Even when I park in full sun and stop for lunch. Hop in, and a short time later, we are cool. My ultimate was when we were in Savannah, GA in August at lunch time and my wife asked me to turn the AC temperature UP because she was cold. The heat index was 130+ later that day so it was not a cold day. Driving through Needles, CA in July the temp was 118 and I had been driving for hours in full sun through the California deserts. I remained sweat free. To be able to drive my 911 all summer and be comfortable, is wonderful.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Get a chip, lower it, and have it corner balanced. In my opinion, that is the lowest hanging fruit that will immediately transform the car.
Cars and Cappuccino
Skip the Porsche classic radio with its micro screen. Get something more period correct (I think '87 had a Blaupunkt Reno) or a newer radio with classic look for a LOT less.
Several threads around here on that topic. Congrats on the car.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
couldn't agree more -- ideally (if you're looking for navigation, etc.), get a bluetooth-compatible radio and the rennline 911-specific smartphone mount --
Driver, not Mechanic
For me, the AC was critical. So was the stereo. I don't care about period-looking stereos. I wanted something for my iPod/iPhone (Bluetooth-enabled if you really want one) and a bit better speakers that fit the same holes (no increase in size).
Steering wheel and shift knob for looks. But that's optional. I'm trying to upgrade the nut behind the wheel with as much autocross seat time as my wife allows.
A few of the items I've done to my 87 Guards red coupe included below. I agree with skipping the classic radio bit, I went with a Continental radio and ordered the harness adapter and sticker from Bergvill FX. Great guy, answered questions quickly. This adds the classic late 80s look to the car with a modern radio!
https://www.bergvillfx.com/index.php/ I also believe most of the 87 and newer cars are already fused in the critical areas so unless you want special switches to kill something that part is already done. I would suggest installing all of the SpokeWorks LED lights for the rear. I've done all of them and am very pleased with the quality of the boards and how they make the rear of our cars seen. And in front I've also added Xeon 55W projectors which makes driving at night a pleasure. Some don't like the modern look of clear lenses but you can also add fluted lenses to this setup. Lastly I would suggest getting a solid state DME relay. The relay is something everyone says to have a spare but going solid sate is the next level, plus having the fuel pump prime is a really nice modern feature. Good luck on your next updates, I'm sure you'll enjoy the car even more as I did with a few of the items I've mentioned. CTopher |
Nice car! +1 on the solid state DME relay. You also might want to look into the Rennline aluminum interior door handles. Much better than the plastic factory ones.
2000 Boxster S and 2016 Audi A6 |
Cams. Exhaust. AC. Thicker steering wheel.
Then there's the sensible stuff - fuel lines, DME, etc.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Just spent the winter with a new to me MY88 Cab. Modded my supercharged 968 to tasteful Hell and needed a new project. Some of the mods were transferable.
New thicker Momo and hub H4 headlights with CREE V2 LED bulbs Already lowered ![]() Fabspeed exhaust Cat bypass SW chip New Pilot Sport shoes All LED dash/gauge/festoon/brake lights Cap/rotor/leads Fuel/oil filter Wiper reversal 8 new speakers and deck (had old HiFi option) Sub under passenger seat Wanted SS relay but they don't ship to Canada. Have to send to a friend in LA first ![]() New Lloyds - originals are almost perfect so want to keep them covered Recharged A/C Maybe a light flywheel when I get clutch/seal done, depends on cost Came with BBS RS rims so not sure about going back to FUCHS for the $$$ A million fiddly fixes from PO neglect and she'll be 99% |
Counterclockwise?
Taking it to the track
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Porsche installed some additional fuses in the later G's such as the heater blowers but still omitted to fuse the two dash lights (ventilation control panel and the ashtray) and the harness to the front condenser blower. There are too many examples of burnt harnesses from shorts from those lights and the blower to ignore doing such a simple fix without delay. Last edited by Peter M; 04-16-2019 at 02:36 PM.. |
Did use a Griffith/Kuehl supplied wheel well condenser setup of have you come across a secret stash of suitably sized condensers from Ebay??? If you have, do tell!
