HarryD's Avatar
CV Bolts!
Today I was at the Maryhill Loops Road in Washington (lots of fun) and had a pulsation in my gas pedal. When I removed the wheel on the side where the accelerator rod went by the wheel area I found one of my CV Bolts had come out and the moon plate was bent. The other bolt was so loose I could remove it with my fingers.
I flattened the plate and reinstalled the bolts and snugged them up as best I could. If you look at the picture at about 11 to 2 o’clock position (circled) you can see part of the gasket sticking out.
How badly is stuff buggered up?
I am guessing I need to remove the bolts from the CV Joint and replace the gasket. Can I do this without removing the entire 1/2 Axle?
Should I replace the moon plate? Anything else I need to do?
TIA
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-11-2019, 08:59 PM
Pack it up with lots of grease
Old 08-11-2019, 09:23 PM
Still here
pmax's Avatar
I would clean the crud off first.
Read this tome Reconstructing Constant Velocity (CV) Joints
(recent discussion Better 8mm CV bolt?)
Old 08-11-2019, 09:30 PM
HarryD's Avatar
I did read those. not clear to me if I can just separate the inner CV from the transmission, clean the bolt holes and surfaces, replace with new gasket, bolts, washers and moon plates and move on.
FWIW, my boots and CV joints appear to be fine.
Harry
2020 MB E350 4Matic
Old 08-11-2019, 09:56 PM
Still here
pmax's Avatar
I would clean the crud off and inspect all the bolts.
Also, I don't think flattening the moon plate is advisable since ,if I understand the thread correctly, its function is to spread out the load evenly which means it needs to be flat and flush with the CV housing.
Old 08-11-2019, 10:22 PM
HarryD's Avatar
The other 2 bolts are tight.
The moon washer is very soft. It took little effort to flatten so I doubt is spreads the load between the two bolts but instead provides a non rotating surface for the schnoor washers to bite into and counteracts any rotational motion of the bolt (when it is torqued properly).
It is my intent to replace the gasket, washers and bolts with new. When I was 120 miles from home and laying in a driveway on a Sunday morning, this was not an option. I did what was needed to get me through the event and back home. Following the field repair, I drove the car in anger for several miles and rechecked everything to verify it would not fall apart. After another 120 miles, I checked again a found everything intact.
My question is whether I need to remove the entire axle to replace the questionable parts or can I merely pull the 4 bolts, separate the joint from the transmission and install the new parts.
Harry
2020 MB E350 4Matic
Old 08-11-2019, 10:34 PM
Still here
pmax's Avatar
I'll defer to Grady for the details (http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints-
2.html#post1923348
) I think we are both right.
Originally Posted by Grady Clay View Post
The moon plates provide three functions: First they spread the
load so as to not deform the tin cover. Second they provide an
intermediate hardness material for the Schnorr washer to
properly bite into. Finally they connect two adjoining bolts to
prevent turning of a surface between the tin cover and the moon
plate.
The moon plates I ordered, but did not use, seem to be made of harder material than the softer "brass" ones.
Old 08-11-2019, 11:10 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
The short answer is that you do not have to open up the other end of the driveshaft.
However, an upgrade to the Nordlock washers would prevent this from happening again. To do that, of course, you'd remove and replace all the CV bolts as they're generally considered single use.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 08-12-2019, 04:04 AM
T77911S's Avatar
make sure the bolts are long enough so that 2-3 threads stick out past the flange on the tranny side.
you can get new bolts in 5mm lengths at Fastenal. you have to buy a bag or 50 but its still cheaper than buying a full set from here. they also sell the washers.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-12-2019, 04:18 AM
Uncertifiable!!!
Uwon's Avatar
Single use? What makes you say that? I have not come across any Porsche shop manual that suggests single use on a G-body. Have I been missing this for the last 25 years?
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-12-2019, 05:36 AM
piscator's Avatar
For bolts, nordlock and schoor washers, no better supplier than Belmetric. Matt and his staff are very knowledgeable!.
Those bolts are hardened, I don't think they're 'single use.'
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Still here
pmax's Avatar
Johan
Agreed given they are not stretch bolts as far as I know. But the heads do get buggered up so I reused them as exhaust system bolts, the length being just about right !
Old 08-12-2019, 08:52 AM
Cars and Cappuccino
tdw28210's Avatar
I believe the bolts are M8x50mm, 1.25mm thread, (partially threaded) "socket head" bolts. McMaster Carr has them in multiple flavors.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 08-12-2019, 09:23 AM
HarryD's Avatar
Met with my mechanic this morning. Not a hard job and I decided to let him do it for me as the labor cost is minimal.
Harry
2020 MB E350 4Matic
Old 08-12-2019, 11:26 AM
47silver's Avatar
on 75
the bolts are 48 mm if they stick out too far they will hit the banana arm.
1975 911S Targa
Silver Anniversary Edition
gtc gtc is offline
abides.
gtc's Avatar
Replacement boot flanges can vary in thickness, so it is not really helpful to suggest what bolt lengths to purchase. If you also factor in the moon plates and different types of washers, your bolt length could be off by close to 10mm.
Graham
1984 Carrera Targa
Old 08-12-2019, 11:36 AM
Just a word to the wise: After reading this thread, I went out and checked my flange bolts, and HALF were either somewhat loose or not up to spec (60 lb/ft for the 10mm version)! FWIW, I dropped my engine this past winter, and therefore torqued them all to spec upon re-install (April). My car is an '87, so has the moon plates. I will be adding Schnorr washers when I can source them. Lesson learned: check your flange bolts often!
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 08-12-2019, 12:57 PM
A very good point.
I just finished rebuilding two original CV joints and replaced two with new Lobros from Pelican.
I knew I was going to use Nordlocks, (with no moon plate) which are about 2mm thick. I measured the entire stack of parts and wound up using 55mm M8 bolts. If I had blindly used the 50mm suggested length I would have been significantly too short. I used the outer stub axle to measure overall length as the transmission side looks to have more room for longer bolts.
1978 SC Targa
Old 08-12-2019, 01:16 PM
T77911S's Avatar
not sure why 2 washers.
make sure the bolts are 12.9
those look a little on the short side.
make sure there are 2-3 threads sticking out past the flange.
RACE CAR:: sold
Old 08-13-2019, 09:48 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Reread the reconstructing thread. If you try to bolt up the CV without it being surgical clean you will experience another event. Also the bolt torque is critical, 33LBFT is close to the theoretical limit for a 8MM 12.9 bolt.
You got lucky, very lucky, that axle shaft whipping about unattached can cause thousands in damage to anything within its reach, or an accident. Reread/study/memorize the Reconstructing thread like your cars well being depends on it, it does. Everything discussed above is covered in depth, that thread could be a manual.
I learned the hard way as well.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-13-2019, 10:12 AM
