76 911 speed sensor testing?
Just got my speedometer back from North Hollywood Speedometer, installed in my dash. Connections checked and checked again. No reading. I think I have a speed sensor problem. Is there any test that can be done to check to see if it ist kaput?
Old 10-07-2019, 05:12 PM
Ohm meter, voltmeter and/or oscilloscope.
There's a ring of magnets (8, IIRC) in a plastic disk inside the transmission, with a reed switch reacts to a magnet going underneath it. So disconnect the plug at the transmission harness, check you get continuity make/break for revolutions of the wheel. That's the sensor itself. Apparently, it's not unknown for one or more magnets to go AWOL.
Check the harness plug for voltage over ground; one side (the side connected to the speedo terminal) should have nothing; the other should have power. If no power; that's a problem.
Look for voltage peaks on the other plug terminal (connection made & back probed) with ignition on and wheel turning; iirc the output is a 0-5V dirty-looking square wave (like a sine wave with very flat tops) - but just reading voltage/nothing/voltage/nothing is probably a "good enough" test.
If you have signal at the plug but not at the speedo terminal, there's your problem. If the signal wave is present at the speedo terminal, sounds like a problem with that. Or power/wiring to the speedo.
'77 S with '78 930 power and a few other things.
Old 10-07-2019, 05:33 PM
Walt Fricke's Avatar
The speedo sensor (for the electrical speedos) is a reed switch. The 8 magnets alternately close and allow to open the switch. The signal wire from the speedo has the only voltage/current which reaches the sensor. The other wire from the sensor is a ground (even though for some reason Porsche ran it all the way back to the speedo to get a ground). Which means it doesn't matter which way you plug in the two wire connector in the rear of the tunnel - the switch works the same either way.
To check the speedo, manually ground the signal terminal with a tap tap tap to a ground, or from a ground. The needle should move. If it doesn't, the speedo is bad. Not likely, given that the speedo shop knows all about this stuff.
You can check the wiring by doing your grounding at the plug you access by taking off the 4 screw plate over the rear of the tunnel, where the shift coupler is.
If the speedo is good, and the wiring is good, the sensor is bad. Or, with the wires disconnected, put your ohmmeter across the two leads and with the rear jacked up, have someone spin the right side tire while in neutral. Not too big a deal to replace it.
Certainly don't need a scope for any of this, nor a voltmeter. Don't really need an ohmmeter, since the tap tap tap tells you whether the speedo and wiring is good, and if so, then almost by definition the sender is bad. They don't last forever, it seems.
Old 10-07-2019, 05:43 PM
Many thanks to Walt and Spuggy. The engine and transmission and the speed sensor are all transplants into my Slantnose clone. I will do the tests but my general feeling is that it is time to get a sensor on the way. Because of this forum, Pelican gets my business and thanks for providing access to all the knowledge you guys provide. Thanks, again.
Old 10-08-2019, 08:35 AM
7783911's Avatar
I had my speedo adjusted by Palo Speedo and it still read a bit high compared to GPS. They had tire sizes and confirmed the speedo was accurate...could this be a sign of the sensor being bad? (it was off 5KPH liner to all speeds measured. I did double check all connections, PA went ahead and adjusted the pot anyways to adjust for 5 KPH but I am curious now
Old 10-08-2019, 09:47 AM
No, they told me once, that, if I sent in my speedo, they'd only calibrate to what would be "correct" - or factory "standard" - for the instrument. They seem to have done different things for different people at different times - but that's what I got told by the guy i spoke to.
And, standard for the instrument forbids it to ever read low under any circumstances, and up to +10% - mandated by law in various markets.
Add in any differences due to "modern" tire/wheel selections - or a transplanted speedo from another car intended for different tire sizes than you have fitted - and you've got a recipe for 15, 20% off.
Joke-level inaccurate.
PO of my car dismantled the speedo and, (apparently to the disgust of the AHP patrolman watching him do it), ran it repeatedly past one of those radar signs that shows your speed until it was dead nuts accurate.
These days, most everyone has a GPS in their phone that can be used too.
When I replaced that speedo (trip broke), I very quickly got fed up with having to remember that 43 MPH indicated on an instrument with stock calibration was a genuine 35 MPH .
So I fitted a Yellow Box correction unit, measured the rolling diameter of 255/40/17, and adjusted the dip switches until I got readings from the speedo I could actually use/didn't need to ever think about it. Which was about -18%, IIRC.
Old 10-08-2019, 10:22 AM
7783911's Avatar
interesting, i will retest once back in my hands next week but he had tire sizes etc to calibrate with but god knows what PO did or even if the speedo was original. I did try yellow box and it adjusted fine but would erratically swing around at times...they came back and said it was interference and wanted to add a resister of some kind, but i returned and went the calibrated route instead. If all is good upon return I will have to give thought to other instruments or just leave as is..though i would prefer to know engine temp is accurate at a minimum. I know fuel level indicates a bit lower then it should (after fill up to brim shows 95% full) but minimally so i go with that like having extra reserve. alas...this is the price you pay for not having full hx of the car. Appreciate your input
Old 10-08-2019, 10:48 AM
Meh; mine did that. I bought a pocket storage oscilloscope intending to connect it to both sides (eg in/out of the Yellow Box) and see where any fluctuations were. Never got around to it.
I did disconnect the yellow box to test, and noticed that the speedo did do something similar by itself, just not as pronounced/noticeable.
After a year or so, that speedo suddenly died completely. So fitted a spare I had in a box. That one didn't swing around at all - with or without the yellow box. Figured the voltage regulator that started putting out 18V and boiling my battery a few years prior had "hurt" the 15V caps inside the speedo, and they eventually just gave up.
That last speedo is still working great - don't even remember how many years it has been fitted now.
Old 10-08-2019, 12:45 PM
