Backdate conversion hood issues
I've have a 80's 911 SC that was backdated a while back. The hood was replaced with a fiber glass hood, but it does not sit flush. It seems like the curvature of the hood is off, and therefore is elevated a few mm in the middle when closed.
The shop recommended removing the weather strip to have the hood sit lower, but that doesn't seem like the proper thing to do, as i want to protect the electronics.
Does anytbody have any idea of how i can correct this? Just spent a few hours trying to play with the alignment and didnt get any closer to fixing the problem. I hate how the hood looks...
Old 10-11-2019, 07:42 PM
Bill Douglas's Avatar
Can you adjust the latch/closing mechanisim down a bit so it hauls the middle of the hood down to line it up wit the rest of it.
Or put small rubber blocks (a few mm high) on the outside edges to lift them to match the middle.
Old 10-11-2019, 07:49 PM
joefrantz's Avatar
Sounds like it’s bowed. Can you see a difference in the curvature of the hood when it is open vs closed. If possible, adjust the latch forward or slide the hood rearward on the hinges and see if it helps. Be careful of the gap between the hood and cowl.
Joe Frantz
73 911 T
Old 10-11-2019, 08:45 PM
Uncertifiable!!!
Uwon's Avatar
Your body guy does not know much!
FG hoods are sometimes problematic.
It’s now more an issue with the fenders which can be moved up and down a bit.
Skip #1 if you are satisfied with the door alignment.
1. Door to rear quarter, window ledge, front cowl and rocker in that order. If you do not have a few thin shims already, cut out two or three out of really thin scrap sheet metal and paint then to avoid rust.
2. Hood to cowl, and center front. You can adjust cowl up or down a little bit with the stablelizer support in the frunk. Check hood seal against entire front clip.
3. First, fender to cowl (remember rubber thingy in between) and door while leaving most of the bolts off towards front. Then slowly work bolt by bolt towards front matching the edge of hood as you go. Pull up or push down front edge of fender to meet the hood height as the fender will give a little. Pay attention to consistent gap. Have shims ready.
4. Make sure your hood latch is in good working order as you will be pulling it at least 25 times per side in #3, above. Alternative is to run a temporary/emergency wire from the hood latch out one of the headlight wiring holes on the driver’s side.
5. Patience, patience, patience. Plan on 20 hours or so............
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 10-12-2019, 04:16 AM
fiberglass hoods are not created equally. You get what you pay for and the aftermarket world can be
Cruel. I don't see how spending 20 hours playing whack a mole is going to change Much. Time to cut into some fiberglass or buy another hood.
Pics???
Old 10-12-2019, 05:01 AM
(man/dude)
Jonny042's Avatar
If it's only out by a few mm it's probably better than most FG hoods.
Johan's advice is good, sounds like you could start with #3, sentence 2.... loosening anything at the cowl could throw off the gap between fender and door at the top.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 10-12-2019, 05:11 AM
(man/dude)
Jonny042's Avatar
I thought they were all pretty much the same....
But yeah, pics are always good!
Old 10-12-2019, 05:12 AM
The 9 Store
It's a common problem with glass hoods. I prefer the aluminum ones.
All used parts sold as is.
Old 10-12-2019, 04:42 PM
I'm good with tools.
AG81's Avatar
Seeing what you are dealing with would be helpful....
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 10-12-2019, 05:23 PM
i had that problem with a glass hood i originally bought to do my green car. i had to re-radius the hood as it curved too much and sat high in the middle. i tried everything i could think of to get it to sit flat, but ultimately had to cut it and reglass is in a more relaxed arc.
then i sold it and went steel. i extended a short hood...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 10-13-2019, 03:05 PM
It’s extremely hard to get the pictures to show what I mean, but here is an attempt.
Old 10-13-2019, 06:07 PM
It’s like the curvature of the hood curves a little too much and therefore pops up in the middle. Instead of being flush with the side fenders, it’s a few mm higher and therefore you can see the rubber.
Old 10-13-2019, 06:09 PM
The 9 Store
The glass hood wants to curve at an even radius. A steel hood has a structure that keeps the curvature correct for the fenders. You would need to reinforce the glass hood so it stays flatter in the middle. In reality, the glass parts are made for the track. Lightness is more of a concern than cosmetics.
Old 10-13-2019, 07:39 PM
that's exactly what mine did. you're going to have to rework that sucker to get it to fit...
1971 914-6 GT 3.6
1974 911
Old 10-13-2019, 08:03 PM
Can you glass in a few metal strips longitudally down the hood to flatten it out a bit.
Tony
Old 10-13-2019, 09:46 PM
Fixer's Avatar
I know how to fix this and why it is happening, pm me.
Easy fix too.
Old 10-14-2019, 06:48 AM
Flojo's Avatar
when driving fast the windforce presses it down, no worry.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-15-2019, 04:11 AM
