915 Tranny Opinions - Cold vs Warmed
Still in the learning process.
My '84 915 tranny is really a challenge/hot-mess when it's cold...and as it has gotten colder this year...more and more. Really tough to get it into any gear upon start-up.
But...when it warms up, it's fantastic. Shifts as smooth as can be. No issues.
Just checking if this is normal or a significant concern? Any feedback is appreciated.
John
Current:
1984 911 Targa Whale Tail "Gemma"
2014 Boxster S (wife) "Sir Jenson" (She named it...not me)
Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4
Old 10-21-2019, 06:39 PM
Gear oil viscosity?
Old 10-21-2019, 07:13 PM
Don't know. New car to me. The gear oil was changed in June according to paperwork...but no details on the oil.
Current:
Old 10-21-2019, 08:59 PM
Bill Douglas's Avatar
Not an answer but further to add to the puzzle.
My 915 was like magic compaired with what you guys go through. I could shift from third to first. Almost like a Toyota. Warm or cold gearbox or daytime temp' all shifts were easy.
Then... I did an oil change from Swepco to fresh swepco (SAE 90 or SAE 80-90 something like that) and it's an arse to shift unless it's hot. And it takes a while to get hot.
Old 10-21-2019, 09:02 PM
dreichman's Avatar
I agree with both comments above. Try changing the oil. You may be surprised what a difference it can make.
Old 10-21-2019, 10:16 PM
Still here
pmax's Avatar
You run the risk of offending the 915 gods with anything other than Swepco but Kendall hypoid and equivalents are reportedly just as good.
Regardless I treat every shift in my SC as if it might be the last, with apologies to those stuck behind me when the light turns green.
Old 10-21-2019, 11:27 PM
Uncertifiable!!!
Uwon's Avatar
To the OP, your oil may just be low so you might as well just change it to Swepco. You won’t regret it.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 10-22-2019, 04:28 AM
I run Kendall in my 915 with a limited-slip differential. It's what the previous owner recommended.
Take your time and be very deliberate with the shifting. Ensure the clutch is fully depressed.
When cold, shifting into second takes me a little more force. Just slow the shift down.
Now, downshifting from fifth to fourth, well, I've "kissed" reverse a couple times. Just the lightest grind, but man do I feel bad.
Old 10-22-2019, 06:03 AM
Wildman Emeritus
Mine is also cold blooded. Running Kendall in a J Walker rebuild with about 15K on it. As noted above, just take your time until it warms up, then take a little less time once it is warm. Not a Borg or Muncie that you can speed shift.
May want to pull the fill plug and make certain it has enough oil. If not, drain and fill with lube of your choice. Plenty of threads here about brand, viscosity, et'c.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-22-2019, 06:45 AM
Peter Zimmermann's Avatar
Cold shifting characteristics will definitely improve when you use Kendall 80w/90 Hypoid Dino gear oil. DO NOT USE SYNTHETIC (75w/90) gear oil. DO USE patience! If you change the oil yourself always loosen the fill plug BEFORE draining the old oil. Sometimes Mr. Muscle has worked on the car and severely over tightened the fill plug making it almost impossible to remove, which might make it necessary to drive to a shop that has heavy duty removal tools. Always use quality safety tools to support the car before going under it!!!
Keep the Shiny Side UP!
Pete Z.
Old 10-22-2019, 09:46 AM
Regarding your "kissing" reverse while downshifting from fifth to fourth, you should try installing fresh shifter bushings and adjusting your shift coupler. My 915 was behaving identically - I did the aforementioned last weekend and the difference is night and day. I still baby it when shifting from first to second, but the feel is much tighter and engagement is more positive.
A simple procedure too - only took ~$20 and two-ish hours of my Saturday morning to complete.
Old 10-22-2019, 11:41 AM
With the winter looming here in New England, I'll add it to my list of projects for the off-season.
I've been under the impression that the "kissing" is mostly technique. The shifter has a nice positive "elastic" movement away from fifth and reverse, and I've only "kissed" reverse when distracted or plain old tired.
Old 10-22-2019, 12:24 PM
Speed Metal Army General
The Swepco voodoo is real.
Old 10-22-2019, 06:54 PM
This is really great guys. Many thanks. Seriously - many thanks.
Current:
Old 10-23-2019, 11:49 PM
I had this problem; you need to lengthen the fore-aft movement slightly. Mark the position of the coupling with tape, then slacken the nut and pull GENTLY back on the gear lever. Move it no more than 1mm at the coupling. Tighten and test. Repeat as necessary.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 10-24-2019, 12:04 AM
Thanks! Bookmarked this thread and took some notes for when I do that project.
Given the advice, here's another question:
Shifting into second gear, regardless of whether it is an up shift from first, or a downshift from second, takes more force and patience than any other gear.
There's a much more noticeable "synchro engagement" and "clunk" into second. This is more pronounced on track, as it becomes more challenging to rev match and shift smoothly at speed.
Any thoughts?
Old 10-24-2019, 06:52 AM
Walt Fricke's Avatar
Rev matching (blipping) doesn't help downshifting (jusr car control and less stress on parts). Double clutching does help doenshifting - if perfect on the matching, you could shift without the clutch.
Knicking reverse is embarassing, but other than a little more fuzz on the magnets in the plugs, doesn't hurt anything, really. No synchros there, no small engagement teeth to round.
When adjusting the shift coupler, have the shifter boot op so you can see the reverse lockout pawl - be sure it always clicks closed in 5th. If it occasionally hangs up, or you have consciously to shove it full forward into 5th, you need a small fore and aft adjustment.
Old 10-24-2019, 07:17 AM
More good stuff. Another thanks. I'll change the gear oil just so I know what it is. Thanks!
Current:
Old 10-24-2019, 07:07 PM
Someone recommended double-clutching the 915 full-time. I went out today and put about 40 miles on the car around town, double-clutching the entire time and it was FANTASTIC. Not a single shift issue. NONE. It takes a bit to figure out, but wow...what a difference. I also found out, via couple couple badly timed shifts, that I have a very healthy clutch disc. LOL. Win win.
Current:
Old 11-02-2019, 09:52 PM
