Front end vague at higher speeds?
1988 3.2 Carrera, at higher speeds (+130km/h) the front end of the car feels loose. I ride without a spare so I thought that perhaps that was part of the problem. I put the spare back and the front end is still vague at higher speeds. A bunch of years ago, I removed the fog lights and put screens in to cover the holes. Looks good but I started to wonder if those holes are letting tons of air underneath the front end. The car has a stock front air dam and whale tail and when I purchased the car it was dead solid at high speeds. Tires are newish and inflated to 28-35 psi. Any ideas?
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 07-16-2021, 05:34 PM
Check the front toe first.
Old 07-16-2021, 06:10 PM
dreichman's Avatar
Maybe it’s just time for an alignment.
Old 07-16-2021, 11:11 PM
All of the above but a couple of questions-same tire/wheel specs? Do you have the rear spoiler?
Old 07-17-2021, 01:25 AM
All of the above but a couple of questions- same tire/wheel combo? Do you have the whale tail? Not sure about the absence of the fog lights & its effects on the front aerodynamics.
Old 07-17-2021, 01:30 AM
Jeez, in the photo it looks like the camber is way off . Worn tie rod ends ball joints bad shocks etc... have a pro check it out it could be a dozen or more things.
Old 07-17-2021, 07:23 AM
Falken Azenis front 225/45ZR17, rear 255/40ZR17 on Cup 1 wheels. Whale tail. Turbo tie rod ends. I think I am going to get the alignment checked first...
1988 Carrera coupe
1966 250 Ducati
2021 VW Golf TSI
2014 Ninja 300
Old 07-17-2021, 09:13 AM
Bill Verburg's Avatar
I'd try blocking off the fog light holes
Bill Verburg
Old 07-17-2021, 10:03 AM
28 psi seems a little soft. Try 31 and see if that firms things up any.
Richard
87 Targa
20 LS 500
Old 07-17-2021, 12:29 PM
Red Line Service
Marc Bixen's Avatar
Which “whale tail” ? Turbo style with the large lip may not be balanced with the front spoiler lip on a narrow body car!
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 07-18-2021, 11:11 AM
Red Line Service
Marc Bixen's Avatar
How can you see camber in that photo?
Old 07-18-2021, 11:12 AM
block off the foglight holes with tape,
and see if that's the issue
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 07-18-2021, 11:39 AM
T77911S's Avatar
start with an alignment.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-19-2021, 07:27 AM
