cd box failure?
Went for a fun run today...and my car died halfway out. What I noticed was that the cd box was not humming with the key in the on position. After about an hour...the box started to humm again and the car started right up. Let the car idle for 15 minutes and the car would die again after warming up (no humming from cd box) Is this a bad cd box or a bad relay that is responding to the heat?
If the cd box is bad...I am thinking of an MSD unit.Opinions? thanks, Rick '78 930 |
there is a cd box thead on early s. you might pick a spare up. the word rebuildable comes up, but in my hands that my mean something else.
check your power supply and search supermans threads. ( ie relay under passenger seat )
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
I have a 1970 S. I had the same thing happen to me.
Check the ground. The braided wire attaching to the clip on the CD Box to the body. Check all GROUNDING points. If you have to rebuild, call our host for the exchange. |
I thought ground at first....but it dies after heating up, or running for awhile. I will check connections.
when it's dead check positive at the box
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Yes, Paul, thet do ... but, STRANGELY, they aren't in the '65 - '73 catalog!!!
CD Unit, Rebuilt, 911 (1974-77) [Photo] A-602-702-00R $225.00
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
You are referring to positive going into the box I assume. I will have to move a bunch of stuff to see where that is. Intercooler, etc. It makes sense to me that this intermittent behaviour, is due to the effect of years of heat from my turbo on the box. I can only assume that this is the original box('78 vintage), so it's probably seen better days. If there is no power going to the box when it dies, then it's a hunt for a short going back to the fuse panel?
What about the MSD units.....?
"You are referring to positive going into the box I assume."
--- Yes.. I'd probably rig some kind of a test wire to the positive so I could check it quickly.. then attack other stuff while the unit is kaput " It makes sense to me that this intermittent behaviour, is due to the effect of years of heat from my turbo on the box." --- yep.. probably correct.. do you want to bet big bucks before other things are eliminated.. although I always carry a spare CD and coil.. and for instance, is your ignition switch original? " I can only assume that this is the original box('78 vintage), so it's probably seen better days." --- maybe you can borrow a friends " If there is no power going to the box when it dies, then it's a hunt for a short going back to the fuse panel?" --- probably not a short
canna change law physics
I have 2 working CD boxes (used) if someone is looking for one.
PM me for details James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Thanks. I would bet that the box is heating up and failing after idling. It was running fine in the driveway just sitting (you could hear the whine from the box). Just as the engine compartment started to get warm, it shut off (no whine, nothing...). I don't think its a short.
I put an MSD6-AL in my car. It works fine. It is harder to install than the stock unit but it is cheaper if you put the time in for instalation
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
doesn"t the '74-'77 CD fit your car?...LOL ...............Ron
Yes...I see that some have been happy. Was not sure about the turbo application though. I know it worked great in my 67S.
Thanks, Rick '78 930 |
I just installed the msd in my '77 with big noticeable improvements. My cd box worked but had NO whine for the past two years. Go figure. When mine heated up as in real hot weather the car would lack power, it would run but more like lack luster.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
Purely in the FWIW catagoy, Otto (Otto's Venice) hates MSD units. When he was preparing my '70 E to drive from LA to Charlotte, NC last year he removed a MSD unit and replaced it with a stock CD system.
'17 Cayenne |
