1986 Sunroof drain tubes
Hi,
Seeking help/suggestions on how to clean the drain metal tubes - pipes that are located inside the body.
I think that there are 4 drain tubes - 2 in front and 2 in back. One of my front (driver side) is plugged or rusted ....
How to clean or unplug them, any special tool or trick?
thanks
'76 911 Carrera 3 - '81 911 coupe - '82 911 Targa - '83 911 Cabrio - '83 911 coupe (3.6 engine,964 body kit) - '86 911 coupe (ROW 3.2)
Old 10-22-2019, 07:40 PM
Try a length of weed-wacker line to push out any debris.
Old 10-22-2019, 08:43 PM
MichaelSJackson's Avatar
I used weed-wacker line in my drill for the roto-router treatment. Found a clog at the bottom of the passenger 'A' pillar. It bends there and shoots forward along the inner fender for a couple inches. Ended up working it from the bottom as well.
Old 10-25-2019, 02:12 PM
thanks for suggestions
my problem is exactly same as MichaelJackson - tried weed-wacker but it gets stuck near A pillar. Next I will try to use it on drill .... maybe something stronger than weed-wacker will be better .
Any other ideas?
thanks
Old 10-25-2019, 05:54 PM
Designer King
Paulporsche's Avatar
I've used 1 coated wire of a 12/2 Romex electrical wire. That's the type used for 20A circuits in, say, your kitchen. It has a little more stiffness than the weedwacker line and the plastic coating protects the drainline. 14/2 (15A) may also work.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-26-2019, 07:53 AM
I find a length of old speedo cable works best.
Lorne m.
83 SC
Old 10-26-2019, 09:40 AM
thanks
next i will try electrical wire and/or speedo cable.
hope it will clear
stan
Old 10-29-2019, 01:28 AM
Lorne m.
This
Old 10-29-2019, 07:09 AM
Try an old fashioned coat hanger if you don't mind straightening it out.
Old 10-29-2019, 08:15 AM
Senior Member
Jdub's Avatar
Your local hardware store will have stiff "wire" in a loop that is thinner than a coat hanger but has very good rigidity. I have used this whenever weed whacker line folds under pushing pressure and it works beautifully, plus is very long and can go end to end.
'78 Targa in Minerva Blue
Old 10-29-2019, 03:37 PM
82 911 SC - Ancora Imparo
I had an old electric guitar string laying around that I used. Worked great!
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 10-29-2019, 04:28 PM
buy cheap fish tape at harbor freight and cut the end off
Old 10-29-2019, 06:04 PM
4flyboy's Avatar
For what it's worth, this is an issue I've had for some time.
Thanks for the advice.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 10-30-2019, 07:27 AM
